Silent Install using command switches in a batch command
  • Razzor
    • Jul 2005
    Re: Silent Install using command switches in a batch command
    Place "<Silent>" switch in batch file as below:
    Add taskkill to make it completely silent:
    Echo Installing dBpowerAMP and Codecs...
    start /wait %systemdrive%\Install\dBpowerAMP.exe "<Silent>"
    taskkill /F /IM musicconverter.exe
    Echo Done!
    "<Silent>" works for codecs as well, but taskkill is not necessary for these.
    • atamo
      • Sep 2010
      • 10
      thank's for Help, I tried a lot until I realized that "<[COLOR="red"]S[/COLOR]ilent>" swich is case sensitive :vmad:
      • LostElf
        • Mar 2015
        Hi everybody, I'm trying to install a few codecs silently but with no luck... I tried using <Silent> and --silent but for these codecs: Arrange Audio, Audio Info, Channel Split, Id Tag Update,MonkeysAudio and WavPack it doesn't work and the setup runs in standard mode... can you help me? Is it possible to silently install those codecs? Thanks!
          • 46229
          These old installs do not support it, sorry.
          • LostElf
            • Mar 2015
            Absolutely no problem, Spoon! I was only curious to find out if (and in what) I was making any mistake. Thank you VERY much for your amazing work, you're GREAT!! ^_^
            • SirLauncelot
              • Nov 2015
              I am trying to do something similar, but it doesn't seem to work. I think I have correctly escaped the <> characters. But I can't even do this from a CMD prompt.
              FOR %i IN (*.exe) DO "%i" ^<Silent^>
              or even this from the command line:
              "dMC-R15.3-Ref-Registered.exe" ^<Silent^>
              It really doesn't like the <> characters. In future builds, could you incorporate normal options like /s?
                • 46229
                #22
                The new installers accept --silent
