Silent Install using command switches in a batch command
  • XL-DJK95355
    • Nov 2003
    [FONT=Tahoma]
    I am completely lost.......I need silent command switches for installind db10....I'd like to incluse the install in my WinXP CD.........what command do I use?
    Steve:vmad:
    • 46229
    Re: Silent Install using command switches in a batch command
    run dmc setup passing:
    <Silent>
    on the command line.
    • XL-DJK95355
      • Nov 2003
      <Silent>
      Thanks, Spoon, but I tried it and it didn't work, here's an example of a batch command I use for Nero Burning Rom, using a similar technique:
      ECHO Installing Nero Ultra Burning ROM v6.0.0.23
      ECHO Please wait...
      start /wait %systemdrive%\Nero\Nero60023.exe /silent /noreboot
      ECHO.
      ECHO Registering Nero Ultra Burning ROM...
      REGEDIT /S %systemdrive%\Nero\Register.reg
      ECHO.
      EXIT, I even tried that particular command structure, and even THAT didn't work with dB10....... now, I'm lost...lol
        • 46229
        make sure you have the right case:
        <Silent>
        it should work, Sveta installs dMC this way.
        • XL-DJK95355
          • Nov 2003
          <Silent>
          Well, Spoon, it doesn't...so I'm completely lost....... I have no Idea:yawn:
          This is what I've inputed to try out:
          Start - Run - c:\db10Gold.exe /s
          Start - Run - c:\db10Gold.exe <Silent>
          Start - Run - c:\db10Gold.exe /S
          Start - Run - c:\db10Gold.exe -u -s
          they're no good, I still get the Install popup as orignal
            • 46229
            Try:
            Start - Run - "c:\db10Gold.exe" <Silent>
            If will offer to uninstall the old version, I have fixed this for the final r10 release.
            • XL-DJK95355
              • Nov 2003
              Try:
              THANKS ALOT SPOON! :D :D I just wanted to know if there's any way to exclude the final window? Does this switch work with File Selector and Powerpack?
              THANKS,
              STEVE :D
                Thanks for that switch. BTW if you want the last screen to disappear when its finish installing just use the taskkill.exe to stop it. Like this, "taskkill.exe /F /IM musicconverter.exe". That worked for me, so I'm guessing you may have some success with it also.
                  • 46229
                  Those two are using the old installer so not until they are updated.
                    Is there anyway to make this work thru a DOS batch file?
                    It works fine in WinXP, using Start->Run.
                    But if I try to do it thru a dos batch file it doesn't work.
                    IE)
                    start /wait %cdrom%\other\$more\dbamp\setup.exe <Silent>
                    start /wait "%cdrom%\other\$more\dbamp\setup.exe" <Silent>
                    etc
                    never works. I either get spit out of the dos command window, or i get
                    The syntax of the command is incorrect and it pauses my installation in
                    even just going to my DVDRom drive and into the folder and typing
                    setup.exe <Silent>
                    i get invalid syntax.
                    Like I said, it works fine using Start->Run. But I dont want that.
                    I want it to be able to install via COMMAND window.
                    I have an unattended install DVD, I'd like dbpoweramp to be installed automatically. I utilize BATCH file commands to install all the programs.
                    This one does not work. Any ideas?
                        to run silent use /s
                        • koden
                          • Jul 2004
                          I'm using this:
                          @echo off
                          ECHO.
                          ECHO Installing dbpoweramp
                          ECHO Please wait...
                          start /wait %systemdrive%\dMC-r10.exe /s
                          ECHO.
                          it's still gives me install screen
                          I have tryed this:
                          start /wait %systemdrive%\dMC-r10.exe <silent>
                          then nothing happens...
                          what am I doing wrong??
                            • 46229
                            Try:
                            start /wait "%systemdrive%\dMC-r10.exe" <silent>
                            • Terra
                              • Jul 2004
                              wrote my own installer for this, including a codec pack for all codecs
