PerfectTUNES
  • SkyRip
    • Oct 2012
    PerfectTUNES
    Is PerfectTUNES incorporated into DBpoweramp Reference or is it a separate piece of software. On the site it reads like it is a separate piece of software but I'm not sure. If so, I thought DBpoweramp had all that functionality. Can someone provide a little more information about this? Thanks.
    Re: PerfectTUNES
    PerfectTUNES is separate from dBpoweramp.
    If you install PerfectTUNES you will see it is very different from what dBpoweramp is.
    • SkyRip
      • Oct 2012
      Re: PerfectTUNES
      Thanks Spoon. I'll install them both and check them out.
