How to Edit Properly and Efficiently?????
  • Tom Swaman
    • Oct 2011
    • 258
    I am still having trouble with apparent inconsistencies in editing data in file titles using "edit-tag". Sometimes this works just great and sometimes, the edit I make does not remain. I am open to any suggestions, instructions, etc.
    I often edit single file data and often edit multiple file data, what must I do differently to make both work?
    What does "single edit" mean and when should this be used and how should this be used?
    Thank you,
    Tom
  • dbfan
    • Jan 2011
    • 937
    Re: How to Edit Properly and Efficiently?????
    It should make no difference between single or multi edit, as to the tags not sticking what is the tag type again?
    • Tom Swaman
      • Oct 2011
      • 258
      I do not understand your question about tag types. Could you please give me one or two examples and I shall try to respond accurately?
      Thank you,
      Tom
      • dbfan
        • Jan 2011
        • 937
        Are the files flac, wma or mp3?
        • Tom Swaman
          • Oct 2011
          • 258
          Thank you Mrspoonsi. Ny files are FLAC. Iconvert any non-FLAC files to FLAC before putting these in my music collection using dbpa.
          Regards,
          Tom
          • HighEnder
            • Mar 2012
            • 19
            I have a problem regarding the playlist functionality. I thought that Asset will generate a playlist whenenver I listen to the server. Can I edit this playlist. If yes, where is it located?
            I upgraded to Asset UpNP Version 4.
            Regards
            Markus
              UPnP servers are not meant to store playlists, it is the control point or player which should do such.
              • HighEnder
                • Mar 2012
                • 19
                Thank you for the quick response.
                That means if a working with the iPad via Kinsky or former with SongBook or in future with Asset Control on the iPad these applications will generate the playlists?
                But how? They do not have access to my server. This will be done by Asset UpnP. Or am I wrong?
                When I am using Asset Control - I have downloaded it today on my PC- where is the button to save the playlist? I haven't found it.
                Is there a folder where I can edit them?
                How should this work from the iPad?
                Regards
                Markus
                  Asset Control currently cannot. I think Chorus can though.
                  • HighEnder
                    • Mar 2012
                    • 19
                    I would be very happy if this feature will be implemented in Asset Control soon.
                    Then I could store the music, I selected depending on my mood, as a playlist, which can be modified some days later.
                    Regards
                    Markus
