Need Help
  • bma52
    • Apr 2009
    Need Help
    I installed the trial dbpoweramp music converter dMC 10.1 and cannot seem to get it to work.
    I have all my music ripped to Windows Media Player 11.
    I want to use my music as ringtones for my cell phone.
    Whenever I try to convert a song it tells me I need a codec. I go to the site and download the codec for XP. When I try to install it I get,
    Error whilst running 'C:\Program Files\Illustrate\dbpoweramp\dbConfig.exe'
    I click Ok then it tells me Windows Media needs to be restarted.
    I have uninstalled and reinstalled both the dMC and the codec and nothing seems to help. I even tried to rip a song from the CD and nothing. No errors, notips, no windows, nothing.
    Thanks for any help.
    Re: Need Help
    dBpoweramp R12 was a big update, that means all the codecs are for R12 and newer, unles you look in legacy codec central.
