virtualbox 1.6.4 and dMC-R13.1-Ref-Trial.exe
  • pierrep
    • Oct 2008
    • 11
    Hello,
    First thans for dMC.
    I tried to use dMC-R13.1-Ref-Trial.exe on virtualbox 1.6.4 whith guest OS : windows 2003 and host debian etch 4.0 and i have installed some plugins like WMA
    When i use the command on the virtual machine (Windows) in dos mode :
    CoreConverter.exe -infile="C:\input.wma" -outfile="C:\outfile.mp3" -convert_to="mp3 (Lame)" -V 2
    this command line works and job is done
    When i tried the same command from the debian to the virtual machine i'v the answer : "Only dBpoweramp Reference supports command line encoding"
    what's wrong ?
    thanks a lot !
    Re: virtualbox 1.6.4 and dMC-R13.1-Ref-Trial.exe
    You need the Reference Registered version (or active trial).
      Check dBpoweramp Configuration in the VM to make sure the Reference trial is active.
      • pierrep
        • Oct 2008
        • 11
        i've downloaded and installed it 2 days ago.
        i'll check dBpoweramp Configuration and answer you asap
        thanks for your support Spoon & LtData
        (i've to check compatibility with virtual machine before buy it)
        • pierrep
          • Oct 2008
          • 11
          here the configuration
          Code:
          dBpoweramp Music Converter
          Release 13.1
          Registration Status
          Reference: Trial (21 days remaining)
          AMG, GD3 & MusicBrainz:  Access Expired  (Internet Meta Data)
          DSP Effects: Release 3
          dBpoweramp Audio Player
          Audio player extraordinaire
          dBpoweramp CD Writer
          Audio CD burning simplicity
          Sveta Portable Audio
          Enhance your portable player
          So my trial is active i think.
          I don't know where is the probleme.
          Why when i execute the commande line from my debian to the virtual machine it doesn't work and when i use the dos command line directly on the VM it works perfectly ?
          I also tried to launch a bat file (*.bat) from my debian to the VM and the result is the same
          here a commande line to send command to the virtual machine :
          Code:
          ssh -i /root/.ssh/key_dsa -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no www-data@localhost -p 2222 'coreconverter.exe -infile="c:\\0094636362755_01_001_wm9_lossless_full.wma" -outfile="c:\\output.mp3" -convert_to="mp3 (Lame)" -V 2'
          If you have any idea i can do some test
            The trial will activate on a User account basis, so if the coreconverter.exe is run in an effective different account than the dbpoweramp Configuration (shown after install) the trial will not be active.
            • pierrep
              • Oct 2008
              • 11
              ok ! :smile2:
              I change the install, and use the good account and it's better ! but i've and error (the last ??).
              with this command
              Code:
               'coreconverter.exe infile="c:\\0094636362755_01_001_wm9_lossless_full.wma" -outfile="c:\\output.mp3" -convert_to="mp3 (Lame)" -V 2'
              Code:
              dBpoweramp Music Converter           (C) 2008 Illustrate Ltd
              Encoding: mp3
              Audio Source: c:\symphonie.wma
              Audio Destination: c:\output.mp3
               0%-----------25%-----------50%-----------75%-----------100%
               Conversion Failed.
              space beetween "mp3" and "(Lame)" is a problem i think.
              Can i encode this character ? have you a tips to bypass it ?
              thanks a lot for support, i almost finish my tests.
              best regards.
              • pierrep
                • Oct 2008
                • 11
                i suppose it is just a problem between bash and dos during sending command to VM (encoding character problem)
                It's not a dbpoweramp probleme.
