Couple of questions on Reference
  • bluepaul
    • Jun 2008
    Apologies if this has been answered in other threads, but can assure you that I've done a pretty thorough search. I found an old thread that asked the same question, but I think the answer has now changed because the site's pages are slightly diferent in the Registration part.
    I installed the trial version a couple of weeks ago and was very impressed - so I just purchased the Reference version a couple of days ago.
    I wasn't quite sure whether to install the registered version over the existing trial version, but I followed the prompt to uninstall the existing version first. Anyway, It's all up and running, and recognised the previous configuration.
    However, my configuration tells me that I only have 8 days remaining on access to AMG, GD3 & MusicBrainz. What do I have to do to get the 1 year access?
    Also, does Reference now allow you to install CD Writer? I was under the impression it was part of Reference as an optional extra. Is there an extra cost involved in registering it?
    Cheers and thanks for a great product
    Paul
  • Teknojnky
    • Dec 2006
    • 323
    Re: Couple of questions on Reference
    follow the screens, somewhere after you get to the download link should be an amg registration updater thing.
    Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
    Want a random mode based on track and artist relationships?
    [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
    [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
      CD Writer goes final next week, it will appear on registration retrieval for R13 reference.
        The AMG download link is a separate link in the e-mail you were sent.
          That used to be true, but with the new shop there is just one link (registration retrieval), there are 2 links in registration retrieval (when validated) the bottom one is AMG activation.
          • bluepaul
            • Jun 2008
            Thanks for that - I now have 360 days remaining.
            I'm in no hurry for CD Writer so I'll wait until it goes final.
            Cheers
            Paul
