Rio500 Extended Memory
  • fast_elder
    • Dec 2002
    Can anyone tell me the sequence to play the music in my extended memory. The only way I seem to be able to get at it is by playing setting ALL Folders and then stepping through the songs on the internal memory. Every now and then, I must push the right sequence and I get into that extended memory exclusively. Any help?
    Press Browse, use scroll wheel to select External Memory Folder, press scroll wheel?
    • fast_elder
      • Dec 2002
      Thanks, thats it.
      BTW, my RIO500 has been loading fine with RealOne, but I still get a faded (every other pixel is not displayed) on four of my settings menu options(Track, Album & Artist) Anyone ever hear of this, or even better, a cure? I rolled back to version 2.15 and its still there.
      • fast_elder
        • Dec 2002
        Faded screen
        Forget the last. The options are faded because I hade the ID3 info set in the off position
