Converting midi to mp3 or wav
  • Anabela
    • Apr 2008
    [SIZE="4"]When using the trial version, I was always able to convert my midi´s. Now with the registered version I always get an error message saying bad midi file.
    Am I doing something wrong? I have the midi codec installed.
    Please help. Thanks.[/SIZE]
    Re: Converting midi to mp3 or wav
    Nothing wrong, are you converting files you converted previously?
    • Anabela
      • Apr 2008
      No. These are new files.
        You need to try some older files, the new ones might have issues.
        • KimBl
          • Jan 2009
          I need to do this also -- FF does not recognize .mid files. I convered a .mp3 to .wav with no problem. But I'm starting off with a .mid now.
          • Wayne
            • Aug 2002
            • 1254
            Have you installed the midi codec?
