ActiveX component can't create object: 'dmcScripting.Converter'
  • aabra1
    • Sep 2017
    • 8
    #31
    Re: ActiveX component can't create object: 'dmcScripting.Converter'
    Could it be a permissions issue i.e. user does not have FULL administrator privileges?
    i am local administrator on both systems.
    ActiveX has in the past been used as an exploit by malware writers. I wonder if it's being blocked for security reasons. I would check Windows and/or antivirus settings.
    Antivirus is disabled.
    If ActiveX is blocked for security reasons. Were would I check Windows settings for that.
    I would not think windows is capable of blocking individual ActiveX object.
    It does not block other objects from being created, the objects bellow are working just fine.
    Scripting.Dictionary
    Scripting.FileSystemObject
    WScript.Shell
      • 1915
      #32
      In our company we have seen problems with some ActiveX components (registration) in dependency if you install the ActiveX component as 'admin' or 'administrator'.
      • Jailhouse
        • Sep 2016
        • 388
        #33
        Take a look at this Stack Overflow thread.
        • aabra1
          • Sep 2017
          • 8
          #34
          Thanks a lot for this pointer.
          turned out that both syswow64\wscript.exe and system32\wscript.exe are 32-bit engines on my system. they both about 138kB
          when i explicitly call them
          >>syswow64\wscript.exe tester.vbs
          or
          >>system32\wscript.exe tester.vbs
          in the task manager they show up as *32 process - so they are both 32-bit
          I searched and found wscript.exe about 165kB elsewhere. so that is 64-bit version.
          and when i call that explicitly
          >>blah\wscript.exe tester.vbs
          it shows up w-o *32 - 64 bit process
          and then it works.
          so dMCScripting.dll from 16.2 release that is being called when 'dmcScripting.Converter' gets created is obviously 64-bit.
          and needs 64-bit wscript.exe engine to be recognized.
          So I am good now. it works.
          thanks
            • 46230
            #35
            If you were double clicking the .vbs file, how was it running the 32 bit version of wscript?
              or
              To help other windows 7 64-bit users, can you post exactly where the 64-bit wscript.exe resides?
