Converting rm in GUI works but scripting fails
  • henrik
    • Mar 2005
    I have a Real Audio file (.rm) that I downloaded from
    rtsp://a1629.v1854c.c1854.g.vr.akamaistream.net/ondemand/7/1629/1854/v001/www.wbez.org/ta/274.rm
    I can convert the file to mp3 using the GUI. However, if I try to use scripting, it fails with the following message:
    "Support for the audio type '.rm' might be obtained at 'Codec Central'" etc.
    I can successfully converted other .rm files by scripting dBpowerAmp Music Converter, but this one fails when scripting.
    I have tried several different MP3 settings in the scripting procedure (mono/stereo, different bit rates and frequencies) but nothing works.
    Any suggestions?
    Re: Converting rm in GUI works but scripting fails
    Any suggestions?
    That file is being streamed from a streaming server. That may be the problem.
    • henrik
      • Mar 2005
      Hi ChristinaS,
      Thanks for your answer. The file is not being streamed; I downloaded it to my hard drive (using NetTransport).
        Hi ChristinaS,
        Oops, sorry, the way you gave the link to it, I focuses on the link that indicated a astremaing server and I didn't read the comment above it LOL!
        Then maybe it's a case of needing the DirectShow codec rather than the regular Real Media codec.
          You also need the RealMedia DirectShow Decoder installed via RealAlternative.
            LOL! I meant to go back and find the rest of the info and add it to the post but got sidetracked :o
            • henrik
              • Mar 2005
              Thanks for you replies.
              I downloaded and installed DirectShow codec (beta) from
              but nothing changed.
              LtData, I have a clarification question on your comment "RealMedia DirectShow Decoder installed via RealAlternative". As I understand this, I should download Real Alternative from
              and install it. The problem is, it suggests that I uninstall RealPlayer. Should I do that? Can I perhaps install only the DirectShow Decoder?
              Finally, I reiterate that the conversion goes fine in the GUI. So I am a bit surprised that I need a special installation when I want to use scripting, but then again I am not any expert on this.
                Well, you can try it without uninstalling RealPlayer, but it may behave erratically. I wouldn't know, I haven't had RealPlayer installed for ages.
                As for the scripting question, that is odd, but the Real codec has always been weird.
                • henrik
                  • Mar 2005
                  I have done the following:
                  - Downloaded and installed Real Alternative (and uninstalled Real Player in the process)
                  - Uninstalled the dBpowerAMP Real Audio codec using the Control Panel - Add/Remove software
                  - Added ".rm" and ".ra" to the text file in Start - Programs - dBPowerAmp Music Converter - Configure DirectShow Decoder
                  - Re-run "dMC Configuration"
                  At this point, the GUI conversion works (and it even works far faster than before with the progress bar working). But Scripting still fails with the same error as before.
                    You might have 2 dbpoweramps installed to different locations?
                    • henrik
                      • Mar 2005
                      The error was my mistake. In the filename that I sent to dBpowerAMP's scripting interface, a space creeped in at the end, so the filename was "274.rm " but not "274.rm".
                      This caused the error. Now everything works fine. Thanks to everyone that tried to help; I apologize for the inconvenience.
                      (But I am enjoying the faster conversion due to RealAlternative.)
