need codec for .uax to (.wav, .mp3, etc.)
  • jediguy91
    • Jan 2005
    • 12
    Is there a codec for .uax (unreal audio format)?
    If not could one be developed?
    tx
    Re: need codec for .uax to (.wav, .mp3, etc.)
    Try dMC AUxiliary Input http://forum.dbpoweramp.com/showthread.php?t=5362
    • jediguy91
      • Jan 2005
      • 12
      unfortunately, i can't play the file, so auxilary db is out of the question...
      If you know a player for .uax, that could be helpfull
      tx
        tx
        Have you checked www.unreal.com ? Maybe there's something there. In any case, since these files are for some kind of games, perhaps when you play the game you can use dMC Auxiliary Input. Well, I'm not a gamer, so maybe this won't work if it takes over the entire screen.
        I'm wondering if the .uax extension isn't a disguised something or other.
        Try to rename it to .ra for instance and see if it plays in Real Player.
        • jediguy91
          • Jan 2005
          • 12
          thanks for the ideas, I could play the game and record with the auxilary at the same time, but it probably would be difficult to get the right sound to play. I'll download realplayer and try changing the extension...
          thx,
          jediguy91
            thx,
            jediguy91
            I don't know that Real Player is the right one, it's just a hunch. The same thing may be done for WMP, and changing the extension to .wma for instance. Trial and error, unless somebody knows exactly what it is.
              One of my friends recoded .uax music using a Winamp plugin and Wave output. However, he has since lost the plugin and the name of it. But now you know there's hope!
                Maybe this? http://www.winamp.com/plugins/detail...omponentFlag=P
                • jediguy91
                  • Jan 2005
                  • 12
                  I got 404'd bye your link
                  lol
                  :vmad:
                  lol
                  jediguy91
                  • jediguy91
                    • Jan 2005
                    • 12
                    I'm going to boot up my Linux partition and see if mplayer supports .uax
                    jediguy91
                      lol
                      :vmad:
                      lol
                      jediguy91
                      Oh, interesting. I found that somewhere and I'm sure it was working.... will try to find it again.
                      Ok, try thsi: http://www.winamp.com/plugins/browse...C&query=unreal
                      • jediguy91
                        • Jan 2005
                        • 12
                        I tried that after i installed WinAmp, but i couldn't get it to work, but it was umx instead of uax, similar but not the same... Oh well, I'm going to see if Mplayer on Linux can play it...
                        tx
                        jediguy91
                          Are you trying to play the Unreal Tournament music?
                          • jediguy91
                            • Jan 2005
                            • 12
                            no, im trying to play Americas Army music.
                            Why they are using unreal audio format is beyond me.
                            I just want to play them thats all.
                            jediguy91
                              Oh. Hmm, don't know if I can help you then.
                              Hmm, google suggests you try this, mabye? http://wiki.beyondunreal.com/wiki/BatchImportCommandlet
