Cleaning Up Database
  • gleicher
    • Jul 2004
    I am a new user to poweramp/player - but i am planning to register soon.
    I was wondering:
    My collection of music is continually evolving, from a variety of sources (if nothing else, it sits on a server so I can serve music wirelessly around my house). Becuase of this, files are continually being moved around, and tags are often being updates.
    is there a quick way to have dAP re-scan the music "database" (tree of files) and update itself to find new stuff (and/or changed stuff)?
    having to clear the database and start over from scratch is a little drastic and time consuming.
    thanks,
    mg
  • gleicher
    • Jul 2004
    Re: Cleaning Up Database
    whoops - i didn't notice the "lookout" options - however, i am not sure what this does other than hang (it is sitting there with an hourglass - but it might be recursing over a big tree)
    will lookout only add new files, or will it handle changes and deletions as well?
    thanks,
    mg
    • donny
      • Oct 2002
      • 761
      when you select "add music" it will just add the new stuff (or at least it should- that is how it behaves on my PC).
        It will look for new files only, to re-read the tags there is a refresh tag from file option.
