Codec for .cvh files
  • cdtjat
    • Jun 2004
    Is there a specific codec that I can download to convert a .cvh file to a .wav file? I've tried sending it to myself via e-mail and that doesn't work. Please help!!
    Re: Codec for .cvh files
    It looks like a .cvh file is a type of complex server file. Perhaps someone familiar with this type of file could advise on how to break out the audio portiion of the .cvh file or whether it is even possible to do so.
    If you can somehow play the audio you could record it to wav through your soundcard using dMC (dB Music Converter) and Auxilary input.
    Bill Mikkelsen
      Bill Mikkelsen
      • eli edri
        the only known way for now, is to E-mail the file, the the program converts it, and instead of sending it, you can save the attachment in the file menu, or pick up the converted file from your E-mail folder (click on find .wav to get the file if it's tooo hard).
