Freezing on first play
  • cuparboy
    • Dec 2003
    • 25
    When I start up dbpowerAMP and go to play a tune either by double clicking on it or by using the right mouse button almost every time the whole system will freeze for up to two minutes while the song loads and plays. I am wondering if dbpowerAMP has any history of conflict with any other programme I may have installed? I run Windows 98 SE,
    AMDathlon 1500+, 512MBram, and have Windows Media Player 9 installed (this problem preceded the update to Win Media Player). Anyone any ideas? Thanks in advance, even if you just read this far.
    Re: Freezing on first play
    What type of files are you playing?
      I am playing MP3s. I should add that, after the initial problem, the player will move through a list of queued tunes with no problem. However, once a queue has played the same problems are incurred at starting a new track even though only seconds may have elapsed.
        Try the dAP options menu >> Amp >> and select the other output to option.
        • cuparboy
          • Dec 2003
          • 25
          As I said before, this is the best player out there. Now I have to add many thanks to its creator for sorting my problem - it now fires up the tunes instantaneously. Thanks Spoon, or should that be MISTER Spoon?
