Can any1 help :(
  • angel
    • Oct 2003
    Can any1 help :(
    Ok when playing music with kazaa lite, than playing another track with dbpoweramp [ kinda like mixin the 2 tracks in ] dbpoweramp dont seem to play, it be the same if i played a track with dbpoweramp 1st, than kazaa's player wudnt work.
    i never had this problem b4, i could play 2 songs at the same time b4 like dbpoweramp and winamp playing together
    plz plz plz help me :(
    Re: Can any1 help :(
    I keep getting computer output is already in use ?
      Possibly your sound card can only play one output at once (pausing is the same as though it is playing).
      You might try dAP Options Menu >> Amp >> Sound Output set to DirectX.
        Why are you so into wanting to play both at the same time? Is this something that's gonna make or break your day? I would help if I knew, but I think you better go on with life knowing it is ok to listen to one at a time
