dB cannot read my CD-R drive
  • stkndg
    • Jul 2003
    Not dB's fault, but I've been having difficulty with my CD-R lately. I think it may be a driver problem, but conveniently, the mfg has just gone out of business (CenDyne). When I first installed dB, it couldn't read my drive and you gave me some advice to get it working. Could you refresh my memory? I believe you sent me a link to test the drive.
    Thanks much,
    KM
  • Clete
    • Aug 2002
    • 30
    Re: dB cannot read my CD-R drive
    Thanks much,
    KM
    Found a couple of drivers at http://driversguide.com/
      Which Windows version?
      • stkndg
        • Jul 2003
        Sorry - forgot to mention - XP.
        • stkndg
          • Jul 2003
          Thanks. I'll check it out.
            Select Audio CD Input >> Options >> Advanced and set Command to NT/2000 Built-in (Limited).
            • stkndg
              • Jul 2003
              I did. I think it's a Windows problem. Now it doesn't even see that drive. It doesn't see my DVD now, either.
              • RossRoy
                • May 2003
                • 403
                Maybe it's your disk controllers going bad. I've had that problem recently. My hard drives would just disconnect and not be recognized by the BIOS anymore, and, if I left the computer OFF for a full night, the day after it would boot up for about 15 minutes and then disconnect again. Turned out if was a controller problem, had to change the motherboard.
                  Check the connectors are pushed into the drives fully and MB.
