Jazpiper help needed
  • DJScott-e
    • May 2003
    Hi All,
    I have a Jazpiper mv32p without the parallel cable. Does any one know if I can transfer mp3 files to a smart card and insert it straight into the player and listen to the files???
    Any help would be appreciated as the cable is no longer availbale and i would like to use my player. I have tried using this program (Which I might add looks like a good program) but wioth out the cable it is no good.
    I have a USB card writer and a 32 meg smartmedia card. I have tried numerous converters ranging fram lame to mp3Pro but with no luck.
    Please help me out some how
    Cheers,
    DJ Scott-e
    The files are stored in a special format on the flash card so it is not possible to write them using the PC (without the jazz piper).
    • egg
      • Aug 2003
      Sorry to bump an old thread but does anyone know how to do a pinout diagram for the cable? I am also missing my cable and want to use the player again!
      The USB one would be the easiest to Pinout as it only has 4 wires but a parallel will do as well.
      If anyone can help, please e-mail [email protected]
      Tim.
