player not on screen
  • Baloe
    • Apr 2003
    • 95
    I only get the player in mini player. The normal size is gone, this with the new 12.
    Baloe
    Re: player not on screen
    Try this to reset dAP to factory settings: http://forum.dbpoweramp.com/showthread.php?t=403
    • Baloe
      • Apr 2003
      • 95
      Thanks for reply.
      It doesn't do the trick. I remember that i've a long time ago the same problem. The solution was in a file or registry to change the position of the player which was set on 300 or something like that instead of 0 (?). I don't remember the whole trick. So the player is there but the position on screen is not good. Perhaps that you know the whole answer?
      • Craze
        • Oct 2002
        • 308
        Yep. I remember it well.
        Is this with the Default player, or a skin?
        Start/Run: type in: regedit then click OK.
        Reset whatever skin you're using X & Y coordinates to 5 (or any number under 100).
        This should be from HKey_CURRENT_USER\Software\Illustrate\dBpowerAMP\S kin
        Select the Skin's Amp\Amp you're having this problem with and reset X & Y.
        Tell us if you're good to go.
        Here's what you did last time.
        Best wishes.
        Craze
        • Baloe
          • Apr 2003
          • 95
          :komisch9:
          That does the trick! I knew it was a simple answer.
          The x was:4294967055 and Y:4294966837 for skin 1(?)
          and x:481 and y:374 for main amp.
          I change it in 5.
