Keyboard controls for DAP
  • OldCoder
    • Sep 2003
    • 90
    Are there keyboard equivalents that DAP recognizes?
    I am looking at a remote control product that supports supplying keystrokes to an application to control it, but I don't recall seeing any alternative to the "GUI and mouse" approach.
    Have I overlooked it somewhere?
    Re: Keyboard controls for DAP
    Start --> Progams --> dBpowerAMP Audio Player
    I believe the shortcut is called Keyboard Options or something similar. I cannot give you a certain answer as I do not have dAP installed on this system.
    • donny
      • Oct 2002
      • 761
      it is so...
      Start --> Progams --> dBpowerAMP ->configuration -> keyboard options
      • OldCoder
        • Sep 2003
        • 90
        I'm running release 3 beta 6, and I do not see the Keyboard options entry.
        If someone can post a reply with the contents, or direct me to another location to find the table, that would be great.
        Otherwise, I'll trying using the Control Freak programs, and initiate those from a VB program.
        Thanks for your help!
          Not in dAP itself, in the Start menu folder under Configuration. Do you see it there?
          • OldCoder
            • Sep 2003
            • 90
            No, I'm afraid it isnt there. Nor on DAP. I'll peruse the application folders, annd see if it is just a missing shortcut.
              The shortcut is
              "<install folder>dBpowerAMP\config.exe" <keycontrol>
              That is the path to the keyboard control. And it should be in the Configuration folder of dBpowerAMP.
              • OldCoder
                • Sep 2003
                • 90
                Found it on a old Remote Control screen that I had saved to my hard drive.
                That screen has been dumped from the website along with remote control.
                Thanks for your help, if this works I'll be able to get a Griffin AirClick work with dap this weekend!
                • OldCoder
                  • Sep 2003
                  • 90
                  There isn't a config folder in my version, I must have stopped on a odd beta combination of the products, probably about the time Spoon started work on R12.....
                  Oh well...
                    dAP r3 beta six has the config folder and it has been out since Oct 2004. Before that, Beta 5 had the config folder and came out May 2004.
                    If your not using r3 beta six, you should probably update your version.
                    • OldCoder
                      • Sep 2003
                      • 90
                      Thanks for following through so completely, and convincing me to get current. I installed (re-installed?) Beta 3r6, and everything appeared.
                      I am now experimenting with remote and dAP, and I hope to be hooking it up to my "big rig" by the end of next weekend.
