CD Adio Input went BOOM! Please Help!
    Re: Adio Input went BOOM! Please Help!
    Well, when you download the registered copy, use the save option so you'll have it for subsequent use, without the extra need to re-download. Didn't you save it before?
    If you saved it, before restoring your system, burn that installer file to a cd in case it gets deleted by the restore.
    I'm thinking you may be having some other software that conflicts with parts of dBpowerAMP's software.
    Have you installed any special programs for audio/video manipulation? burners/rippers?
    How about something like this: https://www.fileplanet.com/153220/15...leinfo/CD-Grab - this would be a program that has the same name as the one used by dBpowerAMP, cdgrab.exe - and if you installed it it would overwrite the real one.
    • cliffhotchkiss
      • Jan 2006
      • 11
      Re: CD Adio Input went BOOM! Please Help!
      I did save it but restored before I burned it to a disk. As for conflicting software, I don't think so, I run a very lean system and am very very selective of what I have on my machine.
      Also, how it happened, between 2 cd's after succsessfully ripping many dozens of cd's. And with nothing installed recently.
      definitely a puzzle.
      thanks again
        • 46376
        When does it crash? on starting, what if you start CD Input with no CD in the drive, does it load? does it crash when a cd is inserted?
        • cliffhotchkiss
          • Jan 2006
          • 11
          I does not matter if there is a disk in the drive or not. The moment the program is started the error appears, it will not even open the program window or acces the drive.
          bummer, huh?
            • 46376
            Try running:
            • cliffhotchkiss
              • Jan 2006
              • 11
              #21
              closer, closer....The program window opened for about 2 seconds before the error message.
              Attempted varios combinations of resets and restarts with no better luck.
              Thnaks so much, please keep trying!!!
