Popup Info error: "provides audio information for dbpoweramp"
  • mdr
    • Dec 2015
    This started up a few days ago. Unfortunately I don't know why but it's been a little frustrating as it's a quick-access feature I use often.
    I started receiving error popups when starting Windows with the heading:
    The error popup would appear 2 or 4 times. I then realised that the dBpoweramp popup info (when you hover mouse over audio files) was replaced with an error stating:
    "Error: decoder appears to have frozen, corrupt audio file?"
    and the 'Audio Properties' tab in the file properties (right-click on audio file > Properties) is now empty. The only field which is populated is the 'Original Size' field stating '0 bytes' regardless of which file I try it on. I know these errors are related to the 'Windows Explorer Integration' settings in dBpoweramp Configuration, but rather than simply turn the 'Enable Popup Info Tips' setting off, I want to know if this is going to be fixed properly at all? In my line of work viewing the audio file attributes is very useful and used every day.
    Here's a screen shot showing the error:
Name:	dBpoweramp error.jpg
    Any help regarding the dBpoweramp popup info issue would be awesome though, thanks in advance.
    • 44034
    Re: Popup Info error: "provides audio information for dbpoweramp"
    The popup info tip does not work for all file types? such as mp3, wave, flac?
    Have you tried uninstalling then reinstalling?
    Which security software do you have?
    • mdr
      • Dec 2015
      It gives error instead of file info for WAV, FLAC and MP3. I don't use other audio file types.
      Uninstalling all dBpoweramp products, restarting computer, downloading and reinstalling new copy of dBpoweramp 15.3 Ref did not fix it. I still get same error "Error: Decoder appears to have frozen, corrupt audio file?"
      Security: Windows Firewall Control (it's just an interface for Windows Firewall),
      Hitman Pro Alert (enabled).
      Disabling autostart of Windows Firewall Control & Hitman Pro Alert during startup, error still appears on infotip and no info in 'Audio Properties' window.
      • mdr
        • Dec 2015
        I just uninstalled dB again, searched the registry and deleted every entry containing 'dbpoweramp' and 'spooninstall'. Rebooted computer. Installed clean copy of 15.3 Ref and immediately got the attached error messages:
        Here's the Windows Error Report data:
        Problem signature:
        Problem Event Name: APPCRASH
        Application Name: GetPopupInfo.exe
        Application Version: 15.3.0.2
        Application Timestamp: 555c6b2b
        Fault Module Name: vorbis.acm
        Fault Module Version: 0.0.3.6
        Fault Module Timestamp: 50a51541
        Exception Code: c0000005
        Exception Offset: 0000000000001f4f
        OS Version: 6.3.9600.2.0.0.256.48
        Locale ID: 3081
        Additional Information 1: 8eb5
        Additional Information 2: 8eb5a186024d65d81afec547bffe0b0d
        Additional Information 3: 649a
        Additional Information 4: 649aed600492e0195a8b34f6fb31c22e
        Read our privacy statement online:
        If the online privacy statement is not available, please read our privacy statement offline:
        C:\Windows\system32\en-US\erofflps.txt
          • 44034
          vorbis.acm
          That is a windows system driver for decoding ogg vorbis within wave files (they do not exist), uninstall it (it was not standard on Windows). Perhaps it came with a media player.
          • mdr
            • Dec 2015
            I am running Windows 8.1 Pro x64. I just tried installing 15.2 Ref and immediately got same popupinfo crash error. It used to work fine so am wondering what has changed for it not to work.
            The error also still occurs when Hitman Pro Alert is disabled (disbaled before reboot using mscofig).
            There are also no Windows Firewall entries for either dBpoweramp or any elements of it blocking internet or network access.
            I have two other OS with dBpoweramp Ref on them so i'll see if issue is happening on them too.
              • 4015
              Difficult to say and you seem to have ruled out anti-virus/security software.
              Have a checked the Event Viewer for clues when the error occurs? Have you made any other changes to your system recently? Are any other errors occurring on your system?
                • 44034
                See my post (3 before this one).
                • mdr
                  • Dec 2015
                  vorbis.acm
                  Thanks for your assistance
                  Prior to reading your advices I did a generic system search for 'vorbis.acm' and found 2 instances at the following locations:
                  C:\Windows\System32
                  C:\Windows\SysWOW64
                  On reading your post Spoon I felt confident in breaking the file type association of both instances by adding .bak to both filenames so that they became 'vorbis.acm.bak'.
                  Mville, I then checked the Event Viewer and it indeed showed that the faulting vorbis.acm module was located at:
                  C:\Windows\SYSTEM32
                  Having broken the .acm file associations I then opened dBpoweramp Config dialogue and re-enabled 'Enable Pop-up Information Tips' and received no error
                  I opened the 'Audio Properties' tab in File Properties of a .flac file and all the file audio information is showing properly again :D
                  So, it's fixed!
                  Thanks so much for guiding me through to resolution, and thanks Spoon for your program. I've been using it for years, and will continue doing so for years more.
                  • condeccs
                    • Sep 2019
Name:	db capture.jpg
ID:	294121hi! first, thanks a lot for your software, i have been a fan since many years ago... i recently changed from a pc win7 to a laptop win10, and i started to get the same message as the other guy ""Error: decoder appears to have frozen, corrupt audio file?" and the I noticed, that VIDEO mp4 files were freezing upon selecting in explorer.. and I notice the dbpweramp pop up in those files.. but I just want db asocieated with mp3 files... i went to the configuration program and there is a mention for "exclusions" but for "property handler" whatever that means... how can i select which type of files are going to be usiung the pop up feature?? i really love that option, but i dont love the freezing of mp4... thanks in advance!
                      • 44034
                      Which version of dBpoweramp do you have?
