Problem converting FLAC to ALAC...
  • Marauder
    • Apr 2009
    I have a bunch of FLAC files that I am trying to convert to ALAC for iTunes/iDevices and some of the output ALAC files have pops that weren't in the original FLAC files...
    Here is an example
    FLAC Source...
    FFBBC185 I:\Multimedia\FLAC\The Benjamin Gate\['untitled']\02 - Scream.flac
    ALAC destination...
    17ECBE5C I:\Multimedia\Apple Lossless\The Benjamin Gate\['untitled']\02 - Scream.m4a
    I do have "verify files" enabled but the files are not being flagged as
    dBpoweramp Music Converter: Registered Reference
    Release 14.2
    Rerunning the conversion will usually result in a clean file, but sometimes I will have to reconvert twice to get a good output.
  • dbfan
    • Jan 2011
    • 937
    Re: Problem converting FLAC to ALAC...
    Visit codec central >> utility codecs. And install calculate audio crc. After converting convert both the flac and alac file to Calculate audio crc, the CRCs show should be the same
    • Marauder
      • Apr 2009
      I already have Calculate CRC installed, it's what I used to generate the checksums from my example discrepancy posted above. I apologize for not being clear on that point.
        Install a SMART checking program, such as http://www.hdsentinel.com/ which can check the health of your HDD.
        At this stage it is fairly 100% to assume there is no bug in encoding as the decode check would have picked it up, the only thing left is storage integrity.
        • Marauder
          • Apr 2009
          My drives are fine. I have seen errors both writing the output to my local hard drive, as well as my RAID-5 storage array (Samba 3), there have been no SMART errors, and no drive errors in the logs.
          • BrodyBoy
            • Sep 2011
            • 780
            I'm perplexed by this....I have converted literally thousands of FLAC files to ALAC and I've never seen that problem. What other DSPs are in play?
            • Marauder
              • Apr 2009
              No DSP's but I'm now chasing other issues with my RAID-5 array, possibly motherboard/controller related, so Spoon might have been on the right track. I will need to resolve those issues first and see if the problems are resolved.
