Need help installing AAC
  • piperpilot12w
    • May 2010
    I've installed the AAC encoder but keep getting a message something else needs to be installed. I already installed the decoder and encoder from AAC codec central. Then went to the site it directed me to and installed the link it was requesting. Still no luck? Picture 4 isn't showing all the files that should be there.
  • eaglescout1998
    • Apr 2009
    • 203
    Re: Need help installing AAC
    Try this
    This codec relies on the Nero Digital AAC encoder, it can be downloaded only from Nero directly:
    Installation Instructions:
    1) download the Nero codec Zip package from:
    http://www.nero.com/eng/down-ndaudio.php (Direct Link: ftp://ftp6.nero.com/tools/NeroDigitalAudio.zip)
    2) Open the zip file (by double clicking on it) and open the folder win32, select neroAacEnc and copy (Edit menu >> Copy). Open a new explorer window, it is important the old zip window is left open (press Windows Key + E) and browse to:
    C:\Program Files\Illustrate\dBpoweramp\encoder\m4a Nero (AAC)
    In the above folder select (Edit menu >> Paste). After extracting the following files should be present in the above folder:
    encoder Text Document
    Nero Bitmap Image
    neroAacEnc Application
    • piperpilot12w
      • May 2010
      Still the same problem
        You are converting to AAC or M4a (Nero AAC)?
        • piperpilot12w
          • May 2010
          I want to convert from CD to FLAC and AAC
          What is the difference between
          AAC (Advanced Audio Compression)
          M4A (AAC)
          The same message pops up for both choices
            You will probably need the M4a (Nero AAC) not AAC on its own.
            • piperpilot12w
              • May 2010
              I think I installed the Nero M4a codec
              The image shows what I have installed
              • Wayne
                • Aug 2002
                • 1254
                I think you need to copy the NeroAccEnc.exe program to both the AAC and Nero (AAC) encoder folders, or at least point the codecs to where you have put it.
                  Remove the AAC encoder from the Uninstall A Program.
                  • piperpilot12w
                    • May 2010
                    I got it to work
                    Unistalled everything/reinstalled
                    Installed only the M4a (Nero AAC)
                    Installed through Windows 7 Admin account, as opposed to Standard User account if that mattered.
                    • Stuart P
                      • Aug 2010
                      i too am having problems getting the nero aac codec to work now. it worked fine up until i installed this
                      so have uninstalled & reinstalled & followed this instruction
                      Nero Bitmap Image
                      then all i get in the C:\Program Files\Illustrate\dBpoweramp\encoder\m4a Nero (AAC) folder is the 'neroAacEnc Application' when i should see
                      Nero Bitmap Image
                      any help please?
                        You are missing the dBpoweramp part of the encoder, uninstall the dBpoweramp m4a codec, then reinstall.
                        • Stuart P
                          • Aug 2010
                          uninstalled everything related to dbpoweramp. restarted pc. reinstalled just dbpoweramp. copied 'neroAacEnc' and pasted into folder described above. still shows just the 'neroAacEnc Application' in that folder :(
                            When you install the dBpoweramp m4a codec it installs these files:
                            \encoder\m4a Nero (AAC).dll
                            \encoder\m4a Nero (AAC)\encoder.txt
                            ..etc
                            Make sure you are installing that codec to the same folder as dBpoweramp.
                            • Stuart P
                              • Aug 2010
                              ok thanks got it now
