Aux Input to Lame converter problem
  • joemco
    • Sep 2002
    Problem: When I use the Auxiliary Input program to record sound to MP3 using the Lame codec, the conversion *always* takes place at the (very low quality) level of 32kbs, regardless of the quality level I specify. (I also use Lame with the dBpowerAMP Converter and do NOT have that problem there.) As a work-around, I downloaded the Blade codec, and it seems to work satisfactorily. However (and because I read that Lame sometimes works better than Blade), I'd like to fix this (and se Lame with AuxInput). Any info, suggestions, ideas?
    Background info: My OS is WinXP; my PC is from eMachines and has a 1.5Ghz AMD Athlon processor. Have not experienced any other problems with dMC, and love the program!
    Many thanks!
    Make sure you have the latest version of both dMC and Auxiliary input installed.
    • joemco
      • Sep 2002
      Thanks for response. I should have put version info in first post. I DO, however, have latest versions - v.9a for dMC, and v.3 for AuxInput. I cannot tell which version of the Lame codec I have, though I downloaded it from the 'illustrate' site around the end of August of this year.
      Any further thoughts? Should I try to 'reinstall' Lame?
      Thanks! :smile:
        You are setting it by clicking the menu next to 'Record' >> Compression settings?
        Your lame comes with dMC, it should not be installed seperately.
        • joemco
          • Sep 2002
          1. I have set compression level by choosing 'record-with options' and then, in the resulting dialog box, choosing some kbs value like 96 or 128 - used same method with Blade with desired + expected results. However, with Lame, the quality level obtained is always 32 kbs.
          2. I'm sure you're right that the Lame codec 'came with' dMC, but I had forgotten that it was bundled and that I hadn't had to download it separately (as I did with Blade).
          3. My problem, again, is that, though Lame works 'as expected' in dMC, and Blade works 'as expected' in both dMC and AuxInput, Lame *always* acts as if it had been set to 32kbs when recording to MP3 using AuxInput.
          4. For whatever it may be worth, I have purchased and installed the PowerPak, though I believe that the Lame issue predated the PowerPak install.
            On the Lame settings, click Advanced and make sure no preset is selected.
