    • 6189
    #436
    I should have done that from the outset but at the time I would never have predicted the amount of correspondence on here between everyone.
    I wouldn't copy and paste ALL the correspondence. Just key things, like dynamic naming strings, instructions on how to set certain things up, etc. Basically create your own personal "user guide".
    • monsterjazzlick
      • 1764
      #437
      Originally posted by Oggy
      Excel can be used with the Utility Codec, Audio Info.
      Hi Oggy, I did a MS module at college on spreadsheets, but I found it quite complicated! You could use it to mass-print things like peoples addresses for envelopes/letters etc. Cheers, Paul
      • monsterjazzlick
        • 1764
        #438
        Gary, OK, I see thanks. Paul.
        • monsterjazzlick
          • 1764
          #439
          You posted the image of Edit ID-Tag showing different album art in the files you used to test using front and back covers. That's how I knew you had embedded art. (It could also have been the case that you had somehow embedded art in some files and not others; that's still a difference and you'd see the same thing.)
          As Gary said, it's no problem; basically, they're just unwanted tags. Use Edit ID-Tag to delete the art from the files. (I was manually deleting tags from my files last week and found I still had album art in some of them. Edit ID-Tag is my friend.)
          Hi JH, Finally got around to havin' a mess with the artworks again.
          It appears that if the artwork is embedded, then - in ID TAG EDIT - the artwork will appear in the lower left:
          And same results, it seems, if - as in my case! - the artwork has inadvertently been both embedded AND external.
          But if the artwork is set to external, then NO artwork appears in the ID TAG EDIT:
          Whether embedded or external, the artwork appears in foobar. Thanks, Paul
          • monsterjazzlick
            • 1764
            #440
            ... am currently deleting all embedded artwork from entire FLAC library, using ID EDIT TAG.
            Foobar set to 'prefer external':
            • Jailhouse
              • Sep 2016
              • 388
              #441
              As long as its not MS Excel !
              I use Excel for, among many other things, keeping track of my ripped CDs and digital downloads. Nyahh.
              Seriously, use what works best for you. I prefer Notepad when I don't need text formatting. Plus, I can open it, copy text, and close it in the time it takes Word to start. Horses for courses.
              • monsterjazzlick
                • 1764
                #442
                I once thought of taking photographs of my CDs rather than using any form of written documentation. But it never happened, nor has a written version.
                • Jailhouse
                  • Sep 2016
                  • 388
                  #443
                  Embedded art is a tag like any other, except that it contains image info rather than text. If you have embedded art, you'll see either a small version of it or, if the selected files have differing images, a CD image and a note stating that there is more than one image.
                  Exactly. Edit ID-Tag doesn't concern itself with your foobar art setting. It just deals with tags in whatever audio file(s) you've given it to examine.
                  Unless you are processing files with embedded art. Again, the foobar setting has no bearing on what Edit ID-Tag presents. If there is embedded art, it will let you know. If you don't want the art, you can delete it.
                  The setting of embedded vs external is a preference and not absolute. It simply determines which art foobar uses when both are present. If your setting is to prefer external art and only embedded art is available, foobar will show that.
                  • monsterjazzlick
                    • 1764
                    #444
                    Hi JH, Have finally deleted all embedded artwork. So just have external now. Cheers.
                    • Jailhouse
                      • Sep 2016
                      • 388
                      #445
                      Photo images take much more storage space than text. Depending on the size of the images, you might have trouble reading the text. And some CDs don't provide much info on the disc. Text for the win!
                      I'm tracking my rips in Excel because, once I'm done, I'll finally know exactly how many CD titles I have.
                      • Jailhouse
                        • Sep 2016
                        • 388
                        #446
                        Good on ya! And you didn't have to process 17,000 files, like I did. I'm almost jealous.
                        • monsterjazzlick
                          • 1764
                          #447
                          Hi, I am just hoping that my Sony Walkman (when it is fixed/returned) will be able to read (display) the external artwork. Maybe I should have waited until I have received it back from them, and tested it out with a couple of CDs first. Anyway, it's too late now! It was 11GB in total (around 35 CDs). It works fine in foobar though (ie. with different artwork beig displayed for each disc in a boxset). Cheers.
                          • monsterjazzlick
                            • 1764
                            #448
                            JH, It may be a job for later on down the road, but for now I have enough to contend with. One day soon I might actually sit down and listen to some music! Cheers, Paul
                              • 6189
                              #449
                              I can load up all my files in mp3tag and create an automatically create an excel file that contains a complete artist/album/track listing for my entire library, using tag info. (I also like the program for advanced tag editing, and it does way more than just mp3)
                              Then again, I can track the number of albums I have just from info reported by my music server. As of today it is:
                              7170 albums with 96250 songs by 13629 artists.
                              I only have 2,086 artists if I count only artists for which I have at least one album. The other 11,053 artists are artists that only show up on a compilation CD (maybe only one song) and do NOT otherwise have an album in my collection.
                              • monsterjazzlick
                                • 1764
                                #450
                                Thanks very much. Well I have gone for EXTERNAL so I hope I made the right choice. I don't think I want to spend the time sourcing and applying front & rear artworks for a single CD. It's time consuming enough finding a decent front cover a lot of the time. So I think I can do without the extra donkey-work for now. Foobar seems to be great and now now my home PC is reading and writing to the Dell external-HD. And I have made a back-up on a SanDisk micro SD card (which will eventually be slotted into the Sony Walkman, or whichever playback device I end up settling for.
                                Rome wasn't built in a day! Cheers, Paul
