CDGrad.exe and Lumesnion Device Control
  • Darkside4x4
    • Feb 2013
    Lumension Device Control is a software solution that is used to restrict access to physical devices (CD drives, printers, removable storage etc). Since installing Lumension Device Control on my PC I can't rip CDs with dBpoweramp. I have full read/write access to CDs and can rip using MediaMonkey and Media Player. However when I try and rip with dBPowermap each track errors with "Unable to read CD" and a small 57k file is saved to the hard drive for each track.
    On checking the Lumension LEMSS server logs, CDGrab.exe is listed as NOPERMISSIONS WRITE-Denied.
    As CDGrab.exe isn't a physical device I can't add it to the trusted device group in Lumension Device Control.
    Do you know why CDGrab.exe is being detected as a physical device? How can I get detailed information on CDGrab.exe to pass to Lumension support?
    Wayne
    Re: CDGrad.exe and Lumesnion Device Control
    CD Ripper >> Options >> Communication >> Windows Internal
    should work (if WMP works), not this does not allow advanced access such as c2 pointers.
    • Darkside4x4
      • Feb 2013
      Thanks Spoon, that worked. Only issues as you stated is that C2 error pointers and a few other advanced functions won't work with the Windows Internal setting. At least it is a work around until we can find out how to get it working with SPT.
