Problem With All Media Guide
    • 46370
    Re: Problem With All Media Guide
    Yes standard port 80
    • HTDCANBF
      • May 2008
      • 8
      I just purchased the dBpoweramp AMG activation because it expired but the small program I downloaded comes up with the error:
      "Unable to connect to dBpoweramp.com, please check internet connection"
      I have disabled firewall and have no progams in memory blocking any tcp/ip. Plz help!
        • 46370
        Start >> run >> cmd
        Ping reg.dbpoweramp.com, does it get a response?
        • HTDCANBF
          • May 2008
          • 8
          Packets sent = 4, Received = 4, Lost = 0, <0% lost>
          Keep trying, program still doesn't work. Restarted in safe mode with networking and added program to allowed in firewall. Still no luck.
          • HTDCANBF
            • May 2008
            • 8
            Pinging reg.dbpoweramp.com [74.86.240.219] with 32 bytes of data:
            Reply from 74.86.240.219: bytes=32 time=463ms TTL=114
            Reply from 74.86.240.219: bytes=32 time=945ms TTL=114
            Reply from 74.86.240.219: bytes=32 time=1165ms TTL=114
            Reply from 74.86.240.219: bytes=32 time=815ms TTL=114
            Ping statistics for 74.86.240.219:
            Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
            Approximate round trip times in milli-seconds:
            Minimum = 463ms, Maximum = 1165ms, Average = 847ms
              • 46370
              #21
              A program is blocking access then, probabbly the firewall or other internet security program (some change the data stream). Try briefly closing those programs, then try the activation.
                #22
                What firewall/antivirus are you using?
                • HTDCANBF
                  • May 2008
                  • 8
                  #23
                  Thanks for your time,
                  OS is Windows XP Prof x64
                  Symantec Client Security AntiVirus 2006 (disabled)
                  Windows Firewall (I've put the program under allowed & tried turning off)
                  Firewall in Router currently turned off
                  I turned windows firewall off, restarted in safe mode + networking, but still have the prob.
                    #24
                    Windows firewall and router firewall shouldn't affect dMC, I am unsure about Symantec, does it include a firewall feature also?
                    • HTDCANBF
                      • May 2008
                      • 8
                      #25
                      no, just antivirus & spyware/adware protection
                      • HTDCANBF
                        • May 2008
                        • 8
                        #26
                        Alright...I've uninstalled Norton. Still states "Unable to connect to dBpoweramp.com, please check internet connection" I have no firewalls enabled. All other software I have can download all updates with no problems. Is it because I have XP 64bit?
                          #27
                          No, other people are using XP 64-bit and able to connect to AMG. Are you using a proxy server?
                          • HTDCANBF
                            • May 2008
                            • 8
                            #28
                            No proxy, never needed to try it. My exact setup is a Quest DSL Modem, WRT54G router with all firewall/protection off. Windows auto detected internet. I setup home networking for file/printer sharing. I use Norton AV and Windows firewall as the only constant protection programs. I've got Spybot & Adaware installed but never protecting to scan every now and then.
                            Should I open any specific ports, do I need to reg a DLL, maybe excersize some demons?
                            • HTDCANBF
                              • May 2008
                              • 8
                              #29
                              Anyone? I did PAY for this...
                              • Wayne
                                • Aug 2002
                                • 1254
                                #30
                                Have you looked in the windows event logs or any router based logs?
