Batch converter not recognizing audio files
  • JAKW
    • Oct 2014
    • 8
    I trialled an earlier version (?12) without difficulty. Yesterday I purchased the latest version (15). Before installing it, I uninstalled the previous version. Now when I try to run Batch Converter, I get a message saying "No audio files selected for conversion." Finding a similar post here from 2012, I uninstalled, restarted Windows (v7 SP1), and reinstalled: still the same. The files are a mixture of FLAC and MP3 so it's not linked to a specific codec. Any suggestions, please?
    • 46171
    Re: Batch converter not recognizing audio files
    You are able to browse to and select music files in Batch Converter?
    It could be a permissions issue, right click on Batch Converter >> Run as Administrator
    • JAKW
      • Oct 2014
      • 8
      I can browse down to subfolder level, but no music files appear.
      I've done as you suggested an run as Administrator, but with the same result.
        • 46171
        What music type are your audio files?
        • JAKW
          • Oct 2014
          • 8
          A mixture, mainly MP3 and FLAC, as I said in the original post.
            • 46171
            Where is the music saved? in the Music folder on drive c?
            • JAKW
              • Oct 2014
              • 8
              No, on an external hard drive, which worked with the previous version.
                • 46171
                Copy some of the files to the music folder on C:, then browse to the music folder, can they now be seen?
                • JAKW
                  • Oct 2014
                  • 8
                  Okay - I've tried that. Same problem. I can see them in Windows Explorer, but not in Batch Converter.
                    • 46171
                    Browse Batch Converter to:
                    c:\Windows\Media
                    does it list the files in there?
                    • JAKW
                      • Oct 2014
                      • 8
                      No.
                        • 46171
                        Then 100% something on the system is stopping dBpoweramp from accessing the real files. Try to disable your anti-virus software as a test.
                        • JAKW
                          • Oct 2014
                          • 8
                          Turned off anti-virus; no change. Any other ideas?
                            • 46171
                            Sorry no, it is really simple reading a file listing, it has been the same code for 15 years.
                            • JAKW
                              • Oct 2014
                              • 8
                              Regrettably, then, I must ask for a refund of the registration fee.
