Problem scanning library
    • 46231
    Re: Problem scanning library
    Asset elevates when running the configuration program, ensure your normal user account has 'Administrator' access rights (Control Panel >> User Accounts 'change your account type).
    Then try to add the Z:\
    • Newton John
      • Dec 2015
      • 33
      I realise this, hence my post no. 12.
      It is odd though, that you seem unable to answer the questions in post no. 12?
      Sorry, I thought I had made it clear.
      Yes, the mapped drive: \\NAS01-98-10\media\music\flac) appears as Z: in File Explorer >> This PC >> Network locations
      In Asset UPnP Configuration >> Edit Advanced Settings >> Audio Library >> Click the Add Folder button what happens if you select the mapped drive in File Explorer >> This PC >> Network locations >> your name (\\NAS01-98-10\media\music\flac) as (Z)? That is what I was trying to explain - you can select it as \\NAS01-98-10\media\music\flac but not as Z. I can not see Z in Audio Library box.
      • Newton John
        • Dec 2015
        • 33
        Yes, I do have Adminstrator rights in control panel user settings.
        Have also tried remapping Z: just to make sure.
        • Newton John
          • Dec 2015
          • 33
            In Asset UPnP Configuration >> Edit Advanced Settings >> Audio Library, remove existing folder.
            In Asset UPnP Configuration >> Edit Advanced Settings >> Audio Library, click the Add Folder button.
            The Asset UPnP: Select Folder Containing Audio Library window should open.
            Navigate to and select the Z: mapped drive.
            In Asset UPnP Configuration, click the Refresh All button.
            • Newton John
              • Dec 2015
              • 33
              #21
              Many thanks, mville.
              I appreciate your kindness in trying to help me but I have already done that.
              Excepting that, as I say, Z: is not visible in the Select Folder. I have to select the whole path of \\NAS01-98-10\media\music\flac as shown on screenshot in post no. 19.
              • Newton John
                • Dec 2015
                • 33
                #22
                Here is another screen shot so you can see exactly what I mean.
                You can see Z: on the right in This PC but not on the left in Select Folder for Audio Library.
                  How are you selecting the whole path \\NAS01-98-10\media\music\flac? I do not see it in your screenshot.
                  If a mapped drive is showing in File Explorer it WILL be visible, as a mapped drive, in the Select Folder window, or at least it is on my Windows 10 Pro PC 64-bit.
                  I can see the mapped drive in your screenshot (flac (\\NAS-01-98-10\media\music) (Z: )). When you click Add Folder you should be able to select it. I don't understand why you can't.
                  I have just tested this on my Windows 10 Pro PC with Asset 6.1 and a mapped drive Q: is visible and I can select it. It appears in Audio Library as Q:\ and not as you suggest, as a UNC path.
                  If this is NOT working for you, something is not setup correctly. Maybe Spoon can advise, as I am out of ideas.
                  Are you running Windows 10 Pro or Windows 10 Home?
                  • Newton John
                    • Dec 2015
                    • 33
                    #24
                    If you look at the first screenshot you will see the whole path selected. The second screenshot shows the process of attempting to find the path. As you can see Z: just does not appear in Select Folder even though it is clearly mapped. I am using Windows Pro.
                      The question was not, what does the UNC path look like in Asset UPnP Configuration, rather:
                      How are you selecting the whole path \\NAS01-98-10\media\music\flac?, if it is NOT showing in File Explorer.
                      Yes, I see that and it makes no sense to me, that is why I stated:
                      I'll post if I can work out what is going wrong here.
                        [ATTACH=CONFIG]1872[/ATTACH]
                        One last thing, can you post a screenshot of just This PC in File Explorer, showing the Naviagation Pane and the main File Explorer pane (right hand pane) which shows Folders, Devices and drives and Network locations?
                        • Newton John
                          • Dec 2015
                          • 33
                          #27
                          Sorry if I did not explain that very well. I am clicking on the following in turn:
                          1. Add Folder (in Audio Library)
                          2. Network
                          3. NAS-01-98-10
                          4. Media
                          5. Music
                          6. Flac
                          I believe I should be able to click on just Z to achieve this. Furthermore, and the software ought to recognise the sequence as Z. Is that correct?
                          • Newton John
                            • Dec 2015
                            • 33
                            #28
                            It shows the Network location for flac (i.e. Z) that doesn't appear in Audio Library Select Folder
                              Yes, that is correct. In Asset UPnP Configuration, what version is showing?
                              • Newton John
                                • Dec 2015
                                • 33
                                #30
                                Version 6.1
