Problem scanning library
  • Newton John
    • Dec 2015
    • 33
    Hi
    A problem has developed after successfully using Asset UPnP for time.
    Asset scaned some 22,000 flac files on my NAS but didn’t see any albums. Therefore, no albums or tracks appear in Kazoo.
    I’ve tried rebooting everything to no avail. Also, discovered I was not using the latest version of Asset so have tried upgrading to 6.1. Now I find that scanning does not see any files at all. Status: Scanning Library... but no 500, 1,000, 1,500, etc. coming up.
    The network path to my flac files is mapped as Z: - Asset does not see Z: at all but I can set the Audio Library to \\NAS-01-98-10\media\music where the flac files are in a sub folder called flac with sub folders A, B, C, D etc. contain the artists folders alphabetically. This all worked fine before.
    I can see and tag flac files on NAS fine using windows 10.
    Are you able to identify a solution to my problem? Many thanks. Regards, John
    • 46237
    Re: Problem scanning library
    Set Asset to run under the local account, if running as a network service account it will not have access rights to access the share.
    • Newton John
      • Dec 2015
      • 33
      Thanks, Spoon. It is set as Local Account as recommended.
      • Newton John
        • Dec 2015
        • 33
        As a work round I have installed Kazoo Server and that appears to work OK.
        • Newton John
          • Dec 2015
          • 33
          I notice that Linn Kazoo Server sees path to flac files on NAS as it is mapped to Z: but Asset does not. Asset sees it as the full path \\NAS01-98-10\media\music\flac. This suggests I might have some setting in Asset wrong.
          Is there any other critical setting in Asset that I am missing? Thank you.
            On what platform/OS is Asset and Kazoo installed?
            • Newton John
              • Dec 2015
              • 33
              It's Windows 10
              I left it scanning overnight and it managed to get to 1,000 tracks (out of some 22,000)
                Originally posted by Newton John
                It's Windows 10
                So, Windows 10 (and therefore Asset UPnP), is now able to see the network location
                Are your devices connected to the network using ethernet cables or are you using Wi-Fi?
                Have you tried the Refresh All option?
                • Newton John
                  • Dec 2015
                  • 33
                  Yes, it can see \\NAS01-98-10\media\music\flac but not the mapped path of Z:
                  Yes, all ethernet cable
                  Yes, tried refresh each time
                    Something odd, somewhere. Have you added the \\NAS01-98-10\media\music\flac to Windows 10 >> This PC >> Network locations, with the correct user credentials? Has your Windows 10 PC recently updated to the Windows 10 Fall Creators Update?
                    FYI, I just tried Refresh All on my Windows 10, Asset R6.1, configured for a cabled network location.
                    Scanning Library... Tracks 46000, took 39 minutes.
                    Last edited by mville; November 20, 2017, 07:44 PM. Reason: added another question
                    • Newton John
                      • Dec 2015
                      • 33
                      Many thanks, mville
                      It's been a while since I created the network location path \\NAS01-98-10\media\music\flac as Z: but I would have done it with administrator status. I can't see any Windows 10 Fall Creators Update in the update history.
                      It seems strange that Kazoo can see the path as Z: but Asset can't.
                      That was the level of scanning times I had until a couple of days ago. It took 15 min or so to read 22,000 tracks.
                      It's been scanning for last few hours and only managed 500 tracks so far.
                      I'm getting by with Linn Kazoo Server for time being.
                        The mapped drive:
                        your name (\\NAS01-98-10\media\music\flac) as (Z)
                        appears in File Explorer >> This PC >> Network locations?
                        In Asset UPnP Configuration >> Edit Advanced Settings >> Audio Library >> Click the Add Folder button
                        what happens if you select the mapped drive in
                        File Explorer >> This PC >> Network locations >> your name (\\NAS01-98-10\media\music\flac) as (Z)?
                          I am confused. If Asset cannot see the Z: mapped drive, how come:
                          It's been scanning for last few hours and only managed 500 tracks so far?
                          This implies that Asset can see the mapped drive, but something is slowing down the network scan.
                          What changes have you made to you PC since the problem developed? Any Windows updates or other software changes, especially anti-virus/security software?
                          Last edited by mville; November 21, 2017, 11:25 AM. Reason: added another question
                          • Newton John
                            • Dec 2015
                            • 33
                            Sorry, mville. I did not explain that very well.
                            It does see the path if I set it manually with \\NAS01-98-10\media\music\flac - it just does not see it as i have mapped it drive Z:
                            Windows 10 has just done the big update overnight.
                            I have tried disabling Kaspersky Anti Virus and Windows Firewall to no avail. There have been no recent changes here.
                            The only changes I have made recently was to add some video and photos to other folders in media on the NAS. So I have three folders in Media - Music, Video and Pictures. Music contains a folder called Flac that.is futher divided into A, B, C, etc with all the artist folders sorted alphabetically.
                              I realise this, hence my post no. 12.
                              It is odd though, that you seem unable to answer the questions in post no. 12?
