Asset Upnp for Synology
  • Alicantney
    • Jan 2019
    Re: Asset Upnp for Synology
    No, I'm afraid that didn't fix it. Maybe my NAS is just too under-specced. It only has 128MB of memory. 3TB hard drive.
    • timster67
      • May 2014
      • 210
      #107
      I suspect only 128MB memory is far too small. I'm quite surprised Minim worked to be honest, mine uses 250MB, with "only" just over 1000 albums, whereas Asset on the same machine is only using 50MB!
        • 1656
        #108
        Please log into your DS112j using SSH, run the following command:
        uname -a
        ... and post the output.
        It is likely that this NAS model comes with some unsupported CPU model, or a Linux kernel too old for Asset to run. The above command will reveal these details.
        128MB is also less than I had on my lowest-spec test unit (256MB), but it should not prevent Asset from installing.
        • Alicantney
          • Jan 2019
          uname -a
          Hi Peter
          The command returns:
          Linux DiskStation 2.6.32.12 *23824 Fri Sep 7 12:47:49 CST 2018 armv5tel GNU/Linux synology_88f6281_112j
          I hope that is useful, because it means buggerall to me! When I bought it. the NAS wasprobably at the bottom of the Synology range, but was perfect for the intened task as a music server. It can still run Synology's Media Server and MinimServer so no great loss if I can't use Asset, but it would have been nice to try it.
          • Mike-B
            • Aug 2018
            • 223
            #110
            Have you uninstalled Minimserver & the required Java to free up space.???
            Also what other programs do you have running & do you really need them. Uninstalling Minimserver & Synology's Media Server will remove them from your NAS OS, but they're still available from the Synology 'Package Center' on www link.
              • 1656
              #111
              Thanks for the uname output.
              I'm sorry to say that DS112j has ARMv5 CPU which is not currently supported by Asset.
              • Alicantney
                • Jan 2019
                Peter, thanks for that info. No worries, I'll continue as I was. I have a second more sophisticated system elsewhere, and I'll try Asset again in a few weeks' time.
                • Maltjerry
                  • Feb 2019
                  Try deleting the file and re-download, you might have only part of the install.
                  Similar problem, different NAS: DS212J which apparently, has a Marvell ARM 88F6281, single core, 1.2 GHz processor.
                  Fails to complete the installation and leaves an icon with "Error" under Installed packages.
                  I have deleted and re-tried with new download (size 12,391 KB) with no better result).
                  This is the correct download, I take it?
                    • 46231
                    #114
                    This NAS is also ARMv5, sorry it is not supported.
                    • Maltjerry
                      • Feb 2019
                      OK, thanks for letting me know.
                      • RLAbbott25
                        • Jan 2017
                        Synology 918+ , there is no Asset Upnp ?
                          • 46231
                          #117
                          EDITED BY PETER: Intel x86 and x86_64 is supported.
                          === original post ====
                          Sorry no, it has an Intel processor.
                          • PhS
                            • Jul 2015
                            • 27
                            #118
                            Dear Mr Spoon,
                            May I understand by "As far as we are aware, Asset runs on all Synology NAS" that Asset also runs for DS415play with an Intel Atom 1.6Ghz processor?
                            kind regards,
                            Philippe
                            • Mike-B
                              • Aug 2018
                              • 223
                              #119
                              Originally posted by PhS
                              Dear Mr Spoon,
                              This is an interesting HEADS UP; the latest Synology's have mostly gone to Intel processors & a few Realtek. I was considering getting a new Synology with a lot more HP for better video performance. If had done that & found I couldn't use Asset I would've been very p***ed off.
                              I've got this on hold until we know whats going on - or I might go QNAP
                                • 1656
                                #120
                                Clarifying:
                                Intel x86 and x86_64 - that is whole range of Intel, including Atoms - is supported
                                Sorry about the wrong info. I should have replied sooner.
                                You can always get the trial version of Asset and see if it works on your unit, and report the results back. If the trial version works, the registered one will also.
                                If there are errors during the installation, I'm pretty sure they're due to something else than the Intel CPU and need to be investigated by us.
                                Finally, with some Linux knowledge, you can get regular (Linux) version of Asset running manually if installing the SPK fails.
