Asset Upnp for Synology
  • OldRocker
    • Nov 2015
    Asset now has an official package on the Synology, visit the Asset link on the products page.
  • PepsiCan
    • Apr 2014
    • 106
    Re: Asset Upnp for Synology
    The instructions work great. Thank you for that.
    I have one odd problem though. When I start AssetUPnP on the command line (PuTTY), everything will run. But as soon as I close PuTTy, Asset will stop as well. Why is that? What am I doing wrong? I issue the following command
    - login as user
    - sudo -I
    - exec /usr/bin/asset/bin/AssetUPnP
    I then get the messages that everything starts and I am looking a waiting prompt (as in, I cannot enter commands, it is waiting for a programme or command to end). When I close, Asset stops immediately.
    EDIT: Found the reason. Exec will run within the session of PuTTY. So, it is not the correct command to start Asset from the command line. Silly.
    • stefanradev
      • Jun 2016
      How can i do this on a Mac?
      Thank you!
        Have a look here: Asset UPnP OS X Manual
        • seekjack
          • Jun 2016
          • 9
          Hi.I can not download the "asset for synology" from "www.dbpoweramp.com/install.As...berryPi.tar.gz"
          Please tell me the correct address. thank you.
          wget http://www.dbpoweramp.com/install.As...berryPi.tar.gz
          --2016-06-07 22:13:51-- http://www.dbpoweramp.com/install.As...berryPi.tar.gz
          Resolving www.dbpoweramp.com... 89.238.182.185
          Connecting to www.dbpoweramp.com|89.238.182.185|:80... connected.
          HTTP request sent, awaiting response... 404 Not Found
          2016-06-07 22:13:52 ERROR 404: Not Found.
            • 46231
            • seekjack
              • Jun 2016
              • 9
              Hi.
              (The front operation is normal)
              cd /usr/bin/asset/bin
              ./AssetUPnP
              cannot execute binary file: Exec format error
              Where there is no good operation?Please tell me.
                • 46231
                Your synology does not likely have an arm compatible processor.
                • seekjack
                  • Jun 2016
                  • 9
                  My NAS model is: DS-1815+ synology.Whether support?
                    • 46231
                    That has an intel cpu, not arm.
                    • seekjack
                      • Jun 2016
                      • 9
                      thank you.
                      Follow up can support Intel CPU ?
                      Very expect.
                        • 46231
                        You can try:
                        I am not sure if will work though.
                        • stefanradev
                          • Jun 2016
                          Thank you mville!
                          This also very helpful for me. But how can i install the Asset UPnP for Sinology using a Mac? I see that OldRocker has a good description for Windows, but how can i do this on Mac OS X ?
                            • 46231
                            Putty is also available for the MAC.
                            • seekjack
                              • Jun 2016
                              • 9
                              Not Found.
