Asset Upnp for Synology
    • 46231
    Re: Asset Upnp for Synology
    Code:
    http://www.dbpoweramp.com/install/AssetUPnP-Linux-x86.tar.gz
    • bojangles
      • Aug 2016
      My NAS model is: DS-415play synology.Whether support?
        • 46231
        This has an intel atom chip, I think is not supported.
        • ellen_ng
          • May 2012
          intel atom chip not supported, that means only pure intel chip can be support???
            • 46231
            only ARM is supported.
            • erho
              • Aug 2016
              • 53
              #21
              Hello,
              please could someone write a guide for Mac users as the OP did for Win? I am not a computer freak at all and would like to buy Asset for my Synology NAS. But really don't know how to do this with my Macbook Pro.
              • CorbelP
                • Aug 2016
                I'm near to enjoy..I hope.
                Just at the end, when going to http://diskstation:45537, I can't access to the Synology:"sorry, can't access".
                Any idea? Thx
                • erho
                  • Aug 2016
                  • 53
                  #23
                  Originally posted by erho
                  Hello,
                  @Spoon, could you help me please?
                    • 46231
                    #24
                    The instructions in the first post are correct for mac, putty is available on the mac, install it and run.
                      • 46231
                      #25
                      Which synology do you have?
                      • erho
                        • Aug 2016
                        • 53
                        #26
                        DS215j.
                        • CorbelP
                          • Aug 2016
                          installation went well and my Moon Mind is recognizing Asset Upnp on the NAS.
                          Issue:the Mind indicates the library is empty, while I can see the FLAC files in the music folder on the NAS.
                          Not sure I have organized the metadata properly. Any available documentation about filing rules and metadata in a Asset + Mind configuration?
                          Thx
                          Originally posted by OldRocker
                          Installation instructions for ASSET on Synology DS214SE running DSM6
                          Enable the SSH-service (using port 10022) on the Synology NAS via the diskstation manager under control panel>Terminal and SNMP options
                          On a windows pc:
                          Launch "Putty.exe" and open a PuTTy session:
                          Host Name: diskstation (or IP address of synology NAS)
                          Port: 10022
                          Connection type: SSH
                          login as: admin
                          admin@diskstation's password: ********** (enter here Synology's admin password)
                          Code:
                          sudi -i
                          Password:********** (enter here Synology's admin password)
                          cd /usr/bin
                          mkdir asset
                          chmod 777 asset
                          cd asset
                          wget http://www.dbpoweramp.com/install/Asset-RaspberryPi.tar.gz
                          tar -zxvf *.gz
                          rm *.gz
                          cd /usr/bin/asset/bin
                          ./AssetUPnP
                          To autostart Asset, make an 'asset.conf' script file
                          cd /etc/init
                          cat > asset.conf
                          start on started synonetd
                          stop on runlevel [06]
                          exec /usr/bin/asset/bin/AssetUPnP
                          'CTRL+d' to save
                          Close PuTTy
                          Configure Asset with a web browser and the URL http://diskstation:45537
                          Reboot the Synology NAS
                          Enjoy
                            • 46231
                            #28
                            You have configured asset and pointed it to your music location?
                            • Balderick
                              • Dec 2013
                              • 55
                              #29
                              I get the following on my Synology DS213 (DSM version: DSM 6.0.2-8451 Update 1) Am I missing something?
                              Also, the command sudi -i .. should that not be sudo -i ?
                              root@XXXXXStation:/usr/bin/asset/bin* ./AssetUPnP
                              Illegal instruction (core dumped)
                              BB
                              • Balderick
                                • Dec 2013
                                • 55
                                #30
                                I cannot seem to get anywhere with this. The window shows the following -
                                root@XXXXXXStation:/usr/bin/asset/bin* ./AssetUPnP
                                I'm running a DS213 with the 6.0.2-8451 DSM. Am I missing something?
