Asset Upnp for Synology
  • psweetie
    • Feb 2016
    • 76
    #76
    Re: Asset Upnp for Synology
    sorry Peter just read your note in the beta forum with the directory and explanation. Too fast on the trigger.
    Philip
      • 46231
      #77
      It is not currently possible to purchase it, until full release.
      • PaddyBlues
        • Nov 2018
        Hello!
        Is there already information about the release for Synlogy. I would love to buy the PRO version
        Thank you!
        Kind regards
        Paddy
          • 46231
          #79
          We hope it will be quite soon, we ready the new asset for the other platforms.
          • dbpower44100
            • Nov 2006
            • 30
            #80
            Is it possible to add an extra box on the config page which would allow to define custom fields/tags?
            A box which simply reads in the file containing all the field,<nr>,type definitions.
            Similar to the 'Edit browse tree as plain text' feature, since then it won't be nessesary to fiddle with files using putty or WinSCP or such like. Poeple are surely more familar typing text into a www config page.
            Another one I did run into. I can change the display of tags, found that. Quite usefull. What I did miss is the ability to define combined tags so that
            artist
            album
            albumversion
            would become
            artist
            album [albumversion]
            likely needss something to declare xxxx should be formed from album + '[' + albumversion + ']'
            possible and I simply didn't get that? Or not availalbe right now?
              • 1656
              #81
              The next Asset version (R6.3) will provide a page for editing custom field definitions.
              • Mike-B
                • Aug 2018
                • 223
                #82
                Hi folks, sorry if I'm being a bit thick, I see Asset UPnP for Synology has been released (thanks indeed I've been happy beta testing) but what version do I buy ?? the beta was for Mac/Linux, is the one marked as Intel Linux (Asset UPnP Debian Linux - Asset UPnP Premium) the one we select for Synology ???
                Would it be OK to go for it now or wait until Synology OK their support.
                • tegetege
                  • Jun 2017
                  Glad that a proper Synology package of Asset UPnP has been released. I bought the license for Raspberry Pi only to be able to use it on my Synology DS416slim. Is there the possibility to switch this license to the native Synology version of Asset UPnP?
                    • 46231
                    #84
                    It is not released just yet on the Synology, we wait for them to approve it in their store, purchase would be made from Synology.
                    • Mike-B
                      • Aug 2018
                      • 223
                      #85
                      Ahh !!! shame. Synology are not noted for getting a move on so that means my beta-15 copy will run out of its trail period & revert to basic. Any chance you can repost it so as we can grab a copy & to keep the copy until Synology release it.
                      • Mike-B
                        • Aug 2018
                        • 223
                        #86
                        Don't worry, I have a copy on the Cloud
                        • ac16161
                          • Mar 2012
                          • 116
                          #87
                          The testing thread for Asset 6.2 is now locked but the main page on this site for Asset does not have a link to the install release of Asset for Synology. Where can we find it?
                            • 46231
                            #88
                            I have put the link back on the beta test first page, until it is published.
                            • ac16161
                              • Mar 2012
                              • 116
                              #89
                              Thanks. Were there any changes beyond beta 15? I guess there is a rationale for involving the Synology package store but my experience with other third-party software is that users generally go to the developer for the latest version as Synology are not very good at updating the "store". You might be better off having an independent purchase mechanism via this site, as with all the other tools you offer?
                                • 46231
                                #90
                                If they do not supply via their store then there is no easy way of getting the Config page, also when the OS updates I believe it wipes the app if not through their store.
