[Audio Info] codec does not export all tag data?
  • belinea2010
    • May 2020
    • 17
    I have 300 audio files, wav & flac, and I want to export the tag data from each file into a excel spreadsheet.
    I have been reading the dbpoweramp help and it mentions a codec, "[Audio Info] utility codec, this can extract audio properties for multiple files and place them into an Excel spreadsheet" but I cannot get it to work the way I want it to.
    If I hover the mouse cursor over a file dbpoweramp displays all of the tag data but when I use the "Audio Info" to export to a text file it does not export all of the data, it leaves some of it out.
    This is what dbpoweramp displays when I hover over the file
    This is what the [Audio Info] codec exports
    Am I doing something wrong?
    Re: [Audio Info] codec does not export all tag data?
    Yes, you are doing something wrong.
    First, you need to go here: dBpoweramp Codec Central: Utility Codecs and download/install the Audio Info codec utility.
    Next, use the Convert To option (see here: dBpoweramp Music Converter) or use Batch Converter (see here: dBpoweramp Batch Converter) to open the dBpoweramp Music Converter window.
    In the dBpoweramp Music Converter window, select [Audio Info] from the Encoding drop-down menu, set the required options and click the Convert button.
      • 45141
      On the audio info settings page you have to check the box 'extensive audio info'
      • belinea2010
        • May 2020
        • 17
        Thank you for your reply.
        I was doing all that you suggest but I was not doing what Spoon suggested :P
        • belinea2010
          • May 2020
          • 17
          Hi and thanks for your reply.
          I was doing everything you suggest but I did not have the setting for extensive audio info enabled as spoon suggests.
          • belinea2010
            • May 2020
            • 17
            Hi Spoon
            That worked great, thanks.
            I do have another question which I will post as a new question so that it helps other users who may have the same question
