CD ripper doesn´t recognize CD drive
  • Bird
    • May 2018
    CD ripper doesn`t recognize the CD drive. Operating system Windows 10 64bit.
    Operating system shows the CD drive corret and CD drive works properly.
    CD ripper shows CD drive with the information "unknown". For that reason the cd ripper can´t work.
    No other user configred on this PC. No other software for security is installed.
    Form my point of view the CD ripper can´t recieve the corret CD drive information from the operating system.
    Any clarification would be appreciated.
    • 4015
    Re: CD ripper doesn´t recognize CD drive
    Try running CD Ripper as administrator.
      • 43985
      See:
      Microsoft have updated Windows Defender to include an option called "Controlled folder access" this basically limits every program from accessing key areas of the system unless permitted on an individual program basis. By default this option is off for Windows, however if it is enabled you should add the programs
      • Bird
        • May 2018
        Thanks for the statment. But this is what I tried at first. This is not a solution.
        The tool have not the necessary information to work with the cd drive. See pictures.
          • 4015
          Did you try the link in Spoon's post no. 3?
          • Bird
            • May 2018
            Thanks for your note, but I have not the issue that the tool can`t save this files. The tool will not read-in the cd.
            The tool can`t show the correct cd drive information.
            • Bird
              • May 2018
              Yes, but as explained to Spoon it isn`t not the issue to save the files. From my point of view the missing device information is the point.
                • 4015
                Spoon's post no. 3 is not just about saving files, rather that Windows Defender may be blocking access to certain aspects of the windows OS e.g. potentially your optical drive.
                Please Note: the CD Ripper executable is CDGrab.exe
                • Bird
                  • May 2018
                  Okay, in the last version of this feature it was only to protect the drives againts not permited access to the folders.
                  No it runs.
                  Thanks for the very fast support and for this perfekt tool.
                    • 4015
                    Sorry, I don't understand. By the last version of this feature, are you referring to Windows Defender?
                    No it runs.
                    Are you saying it is now working ok?
                    • Bird
                      • May 2018
                      By introducing the folder protection (part of windows defender) with windows version 15..., there was no protblem with the cd ripper tool. For that reason I don`t saw a relation between this feature and the issue that the tool was not able to recognize the cd drive information.
                      Yes, now it runs. Sorry for the typing error.
