Setting volume of Mp3 using Volume Normalize
  • Swamy321
    • Feb 2017
    While encoding a mp3 file, I am trying to set the volume with the command below
    CoreConverter.exe -infile="C:\Temp\Input_001.mp3" -outfile="C:\Temp\Out1.mp3" -dspeffect3="Volume Normalize="-mode={qt}10{qt} -maxamp={qt}100{qt} -desiredb={qt}-.1{qt}" -convert_to="mp3 (Lame)" -V 6
    How do I use Volume Normalize so that the file will play with a default volume?
    • 43928
    Re: Setting volume of Mp3 using Volume Normalize
    You would need -dspeffect1= not 3
    • Swamy321
      • Feb 2017
      I tried with dspeffect1 and still could not set the volume. Essentially I want to be able to control how loud the audio clip plays. I tried the following
      CoreConverter.exe -infile="C:\Temp\9780147519658_001.mp3" -outfile="C:\Temp\Out1.mp3" -dspeffect1="Volume Normalize="-mode={qt}10{qt} -maxamp={qt}100{qt} -desiredb={qt}-.1{qt}" -convert_to="mp3 (Lame)" -V 6
      Can you correct this query? Thanks
        • 43928
        If you convert with the gui, it works as you require? (right click >> convert to)
        • Swamy321
          • Feb 2017
          I dont see a GUI. And I dont see the convert option when I right click on the file. How do I open the GUI?
            • 43928
            Run the program Music Converter from the start menu.
            • Swamy321
              • Feb 2017
              I was able to open the GUI and in Volume Normalize--->Desired Volume, of I set the db to a specific value, then I am able to control the loudness--which is what I need.
              If you can tell me how to do it from command prompt, that would be great. Thanks for your help.
                • 43928
                Once working in the gui, then extract the values:
                Certain Codecs (WMA, and compressed Wave) are difficult to setup as the settings are not guessable. Using CD Ripper it is possible to set the compression settings and read them back from the registry. Open CD Ripper, set the profile to default, set the encoder and settings as desired. Close CD Ripper then open regedit:
