Setting volume of Mp3 using Volume Normalize
  • Swamy321
    • Feb 2017
    While encoding a mp3 file, I am trying to set the volume with the command below
    CoreConverter.exe -infile="C:\Temp\Input_001.mp3" -outfile="C:\Temp\Out1.mp3" -dspeffect3="Volume Normalize="-mode={qt}10{qt} -maxamp={qt}100{qt} -desiredb={qt}-.1{qt}" -convert_to="mp3 (Lame)" -V 6
    How do I use Volume Normalize so that the file will play with a default volume?
    Re: Setting volume of Mp3 using Volume Normalize
    You would need -dspeffect1= not 3
    • Swamy321
      • Feb 2017
      I tried with dspeffect1 and still could not set the volume. Essentially I want to be able to control how loud the audio clip plays. I tried the following
      CoreConverter.exe -infile="C:\Temp\9780147519658_001.mp3" -outfile="C:\Temp\Out1.mp3" -dspeffect1="Volume Normalize="-mode={qt}10{qt} -maxamp={qt}100{qt} -desiredb={qt}-.1{qt}" -convert_to="mp3 (Lame)" -V 6
      Can you correct this query? Thanks
        If you convert with the gui, it works as you require? (right click >> convert to)
        • Swamy321
          • Feb 2017
          I dont see a GUI. And I dont see the convert option when I right click on the file. How do I open the GUI?
            Run the program Music Converter from the start menu.
            • Swamy321
              • Feb 2017
              I was able to open the GUI and in Volume Normalize--->Desired Volume, of I set the db to a specific value, then I am able to control the loudness--which is what I need.
              If you can tell me how to do it from command prompt, that would be great. Thanks for your help.
                Once working in the gui, then extract the values:
