DSP 'Volume Normalize' options: Relation between 'Maximum Amplification' and 'Desired
  • twie
    • Oct 2016
    I got into confusion reading the official DSP help page about Volume Normalize (https://DSP 'Volume Normalize' optio...lume' settings).
    Is the help page clear enough? There is written:
    "Desired Volume can be set higher than 0 dB (which is maximum), setting 12 dB is 4x the maximum, ..."
    The maximum value (for this option) is 0 dB. To what is "... setting 12 dB..." corresponding?
    Could anybody explain in more detail the relation between the set 'Maximum Amplification' value and the obviously corresponding 'Desired Volume' value?
    • 43929
    Re: DSP 'Volume Normalize' options: Relation between 'Maximum Amplification' and 'Des
    Maximum amplification is the allowed multiplication factor, if set to 2 then the volume will only be able to be twice as loud.
    The Desired volume is the level at which replaygain tries to match to.
    • twie
      • Oct 2016
      to
      If there's written "... can be set higher than 0 dB ..." then I understand for example to +1 dB. The implemented slider allows at max 0 dB only. What is my missunderstanding?
        • 43929
        You can type into the box.
        • twie
          • Oct 2016
          Thanx, the limiting slider (vs. possible box values) was my misunderstanding.
