Sample offset
  • stephenng
    • Mar 2016
    Sample offset
    I have Dbpoweramp rel. 15.4(1) installed on a 2010 iMac running El Capitan. I've also connected a Buffalo DVD reader/writer to a USB port. What I would like to know is how I can change or reset the Sample offset for this drive. It's set at +48 which I think was my mistake. I've gone through all the options and cannot find anything that allows me to do this. If I was to delete the app using something like AppCleaner and reinstall it would this help?
    Stephen
    • 43936
    Re: Sample offset
    What exact name is shown for your cd drive?
    • stephenng
      • Mar 2016
      Re: Sample offset
      The app reports that it's a "BUFFALO - Optical Drive". The model * on the drive's label is DVSM-PC58U2VW.
      Stephen
        • 43936
        Re: Sample offset
        If the offset cannot be set, then AccurateRip has self set the offset from a known value.
        • stephenng
          • Mar 2016
          Re: Sample offset
          So, there's no way to reset the value? I notice that in the "~/Library/Application Support" folder there is a sub folder "Accuraterip". If I was to delete that and reinstall dBpoweramp will it work?
          Thanks again.
            • 43936
            Re: Sample offset
            It is likely the settings are stored in a folder dBpoweramp.
            • ec5a
              • Sep 2012
              Re: Sample offset
              Hi Spoon,
              I'm having a similar issue with inputing the wrong offset
              My version is MAC 16 reference,
              PIONEER - BD-RW BDR-S11 is not listed yet and how do I do a offset calibration for this drive.
              Thanks for the advice
              Best regards
              William
                • 43936
                Re: Sample offset
                It is not possible on the mac, once it appears on accuraterip.com then it will auto configure.
                • ec5a
                  • Sep 2012
                  Re: Sample offset
                  Thank you Spoon,
                  Am I able to submit the offset via the windows version of dBpoweramp?
                    • 43936
                    Re: Sample offset
                    Yes if you configure then submit the results, and the drive will appear in the next update (about 4 weeks).
