>> Beta: Monkeys Audio R7 Beta 1
This topic is closed.
    • 43930
    Updated here:
    Updated to use Monkeys 3.99, tagging has also been updated to add extra 'dMC Release 11' features. http://www.dbpoweramp.com/beta/dBpowerAMP-codec-MonkeysAudio.exe 339KB ** If someone with Windows 98SE could try this version, 3.98 had problems (that is why the last beta was not released) ***
  • Razgo
    • 2532
    i can't get it to rip at all. it goes through the process really quick then tells me i have "run out of disk space?"
    i have over 40GIG spare and other codecs can still rip.
      • 43930
      Uninstall it and try the normal release version of Monkeys, does that work?
      What compression setting did you try it on?
      • Razgo
        • 2532
        ok the biggest problem was dmc wasn't uninstalling it for me :( so after a manual uninstall and reinstall it is now working. although it still says ver 6.1 3.97 in dmc configuration.
        • Razgo
          • 2532
          doh! the ripping worked ok but now dap won't play any ape files ripped with the new beta. i can double click on an ape file and it will fire up dap but no play no sound no nothing.
          the file is actually 24,547KB in size.
          • Razgo
            • 2532
            nothing i did would help. i uninstalled dap and dmc and reinstalled everything to make sure that was alright. then installed the latest monkey and got the disk full error straight away after trying to rip. this happens on any pre setting.
            i uninstall and reinstall the previous monkey and he is swinging fine :D
            • JVILLAS
              • Oct 2002
              • 88
              Hi Razgo, I just ripped and encoded 2 Miles Davis cd's using the new Monkey's 3.98, and had no problems. I did Kind of Blue at the normal setting and it compressed to 1.5 to 1.9 in about 3 minutes My ripping speed ave.x30. I also M.D. In a Silent Way, only 2 songs on cd about 38 minutes total,using xtra high, to rip and convert took about the same amount of time as the normal. Compression was 2 .1 and 3.1 . Then tryed Insane to rip and encode took about 5.30minutes with a compression of 2.1 and 3.1, same as xtra high. File info did not show this compression level. Sound quality was excellent except for Insane, it sounded rough on the edges and lacked transparency. I'm going to avoid this setting for now.
                • 43930
                Has anyone on Windows 98 managed to use the new monkeys?
                • Volcano
                  • Jul 2003
                  Not me... I'm on Win98 SE, and I'm afraid the new codec doesn't work here. :(
                  If I try to encode, I get the message "Unable to write to <filename>, disk full?", and on decoding or transcoding to other formats, musicconverter.exe is closed because of an illegal operation.
                  I uninstalled the old codec before installing this one.
                  • Razgo
                    • 2532
                    Re: &gt;&gt; Beta: Monkeys Audio R7 Beta 1
                    any more insight on this one spoon? must be a win98 problem?
                      • 43930
                      Can you run a test, visit www.monkeysaudio.com and download his version of this alpha version, can you compress with his program??
                      • Razgo
                        • 2532
                        i downloaded the 3.98a1_gui and select a wav file to compress and it will GPF on me.
                        MAC caused an exception 10H in module MAC.EXE at 017f:00410fb0.
                        Registers:
                        EAX=00000001 CS=017f EIP=00410fb0 EFLGS=00010202
                        EBX=0040f850 SS=0187 ESP=006ef2e4 EBP=006ef304
                        ECX=006ef328 DS=0187 ESI=006efb1c FS=44b7
                        EDX=00000000 ES=0187 EDI=006efd58 GS=0000
                        Bytes at CS:EIP:
                        d8 e2 dc 0d f0 cf 45 00 dd 19 dd d8 dd d8 8b e5
                        Stack dump:
                        006e2000 00000073 00000000 00000000 00000000 e0000000 41824673 0040f850 00000001 0040f8ac 006ef330 006ef328 006efb1c 00000000 006ef3bc 0040f850
                        • Razgo
                          • 2532
                          i had a look at their forums and someone else said it doesn't work on win98 also. so i might have to weait until the new alpha is beta or released or their latest 3.98 bug for win98 is fixed. after reading the thread it is my opinion so far their must be some sort of bug with the latest release and win98, but nothing to do with dmc being at fault.
                          and so far no one here has come forward saying it does work with win98 yet.
                          • Razgo
                            • 2532
                            PS
                            perhaps make the last version that worked for win98 still availible? i can't find it now :( i think it was ver 3.95?
                            ok i found the last working release that worked for me. it was release 6 ver 3.94b1
                            • zevele1
                              • Sep 2002
                              • 49
                              Originally posted by Razgo
                              PS
                              HOLY COW !
                              Since yesterday evening i had so much troubles with dB
                              I did a massive rip in APE SecureRip with MC.
                              And impossible to convert , to play.
                              All my memory gone when clicking on one song in Explorer.
                              Also the 0 size and mb.
                              But they played in FootBar and TheGrandFather.
                              Rip from dB worked fine.
                              Anyway ,uninstalled db , MC ect ect...
                              Until i found this post.
                              Look like MC use allready the new built ,who is not read by the one before,who is in the download page.
                              Now with the beta installed in dB , all back to normal.
                              But ,hours and hours spent on it.
