Can't get Db to locate robot on Bravo XRP. Help!
  • basaltguy
    • Mar 2011
    Robot works with Primera software but not with Batch Ripper. Error says:
    Unable to locate Primera robot containing drive 'E:', please check connection. Continue Batch Rip?
    I have been through configuration, etc. Any suggestions?
    • 43930
    Re: Can't get Db to locate robot on Bravo XRP. Help!
    Work your way through this thread please:
    I've been getting the "Unable to Locate Primera Robot" error and can't seem to fix it. I've uninstalled everything and reinstalled, downloaded the newest Primera Loaders (Revision 3) as that seemed to help some, and version 1.4 of Batch Ripper but still can't get the robot to work. I can PM the log file to anyone who
      • 43930
      New driver released:
      Changes: Added new detection when two discs are loaded at once (ie two discs stuck together). There is the option when configuring Primera to wait for operator to remove 2nd disc (--stoponmultidiscsloaded="yes"), or automatically reject the disc (--stoponmultidiscsloaded="no"). ** NOTE: After installing
