Sound Cards
  • bbooska
    • Jan 2003
    • 64
    Sound Cards
    Hey there,
    Its TaxTime and i am wanting to upgrade my sound ( AC97 integrated).
    Any Suggestions on a good quality sound Card?
    I run my sound out to a stereo and that is good for volume but
    would like the best Audio quality.
    I also do a lot of ripping of,cd,tape,phono ,to my hard drive.
    I dont mind payin the price but i dont want to pay for what i dont
    need,or for junk.
    Thanks,Bob.
    Windows XP/AMD 1.2/256mb ddr/All in wonder 8500-Dv
  • Burn Baby Burn
    • Feb 2003
    Santa Cruz
    Bbooska,
    I am running Win XP, 1GHz Athlon Thunderbird, 1536MB PC133, 80GB 7200rpm WD HDD, GForce4 4x/8x AGP MX440 64DDR.
    I use Turtle Beach's (http://www.turtlebeach.com) Santa Cruz sound card.
    It's WinXP compatible, costs about $70.
    Tons of features.
    Check it out.
    I like it.
    Their Montego II sound card is good, but NOT WinXP compatible.
    MadDog Multimedia (http://www.maddogmultimedia.com) has a kick-ass sound card, the Predator.
    It's a 5.1, 6.1 card.
    It's WinXP compatible, costs about $60.
    It smokes.
    I also have used CompUSA's (http://www.compusa.com) version of the MadDog card, made by MadDog Multimedia.
    It's WinXP compatible, costs about $40.
    It's good.
    Just make sure the card you buy is WinXP compatible.
    Good luck.
    • bbooska
      • Jan 2003
      • 64
      That Santa Cruz sound card.(http://www.turtlebeach.com/)
      Looks great and reviews are good or better,i think i'll give it a try.
      Was considering a Sound blaster but i see alot of people dont like or have problems with it.
      Thanks,Bob.
      • BestRip
        • Jun 2002
        • 182
        I have a SoundBlaster and I can verify the amount of problems:( On the other hand after having it finally working OK it is really good. I'm not trying to push for it but it has a digital output and my speakers also have digital input and here I want to make a "sales pitch"(?), it is a BIG difference in clarity of sound... If you have the opportunity check it out (whatever brand).
