dMC Audio CD Input - Hotkeys and Comments Field required; plus track play pause
  • wmoonshine
    • Aug 2003
    • 14
    1) ---------
    Hotkeys Suggestions to cut down on mouse use (This would also be nice in the audioplayer playlist editor):
    - Ctrl-A = Select all tracks (standard Windows selection key).
    - Space bar should toggle Check Box of selected tracks On/Off
    - Track Play/Stop/NextTrack/PrevTrack/Pause buttons should be assigned hotkeys. WinAmp uses: Z=PrevTrack, X=Start at beginning of track, C=Pause, V=Stop and B=NextTrack.
    - Hotkey to select Options and Rip menus with sub-keys for sub-features.
    2) ---------
    Comments Column to allow track comments to be individualized, expecially useful for compilation CD's containing various artists. I can't believe this hasn't been implemented yet.
    3) ---------
    The "Spinup for (sec)" setting should NOT apply to playing tracks from within Audio CD Input. Presently, if this setting = 10 seconds, a 10 second pause is placed at the beginning of the first track played as well as between each subsequent track that has a checkmark in its box.
    Thanks for inplementing my 02-24-2004 WishList for 'Copy track listing to clipboard'. I am now a registered user of dbpoweramp music converter.
    • 43930
    Re: dMC Audio CD Input - Hotkeys and Comments Field required; plus track play pause
    See R12 in the beta section, it addresses most of those.
