FLAC or ALAC, which one to choose
  • alexkorsun
    • Apr 2021
    Hello everyone
    This is my first time posting here. As non-technical personnel, I have a question.
    I am going to use dBpoweramp CD Ripper to digitalize my music CDs to audio. It is said that FLAC and ALAC with lossless compression provide the best sound effects. But I don’t know which one to choose.
    I read some articles on the Internet. This author says the size of FLAC is bigger than ALAC, but their quality is not much different (https://www.cisdem.com/resource/flac-to-alac.html). Is he right? I am considering ripping CDs to ALAC.
    • 43965
    Re: FLAC or ALAC, which one to choose
    The quality should be identical, they are both lossless formats.
      • 4015
      The quality is the same. Personally, I would rip to flac, as it is more widely used.
      • alexkorsun
        • Apr 2021
        Thank you for your suggestion, I will think about it.
        • BOOTP
          • Feb 2020
          • 69
          I would definitely say go with FLAC.
          In terms of quality, it doesn't matter but ALAC does not have a built-in check (CRC) to verify the integrity of the audio - FLAC does.
          By using foobar2000 and FLAC, every so often I can check the integrity of my entire library by using Utilities --> Verify integrity in foobar2000. Some people use a 'Test Conversion' in dBpoweramp Batch Converter but foobar2000 is the way I do it, plus you can view the report of checksums.
            • 5749
            For me, this is the key reason to use FLAC (and one that many do not seem to understand, until they have file corruption issues and then it is too late).
