R1.5 AccurateRip hangs at about 75% of the scan
  • rumpel
    • 10
    I bought and installed R1.5 yesterday. Unfortunately, the AccurateRip scan keeps hanging after about 3/4 of the scan and there is now way to tell what the reason is: No error message, no hint on where to find a log file or anything. What can I do?
    Cheers,
    rumpel
    • 43980
    Re: R1.5 AccurateRip hangs at about 75% of the scan
    Can you post a screen shot?
    • AndrewFG
      • May 2010
      • 59
      I also experienced a hang with v1.5 - but it was at the very end of the checking with AccurateRip part of the process. In my case the progress bar reached 100% and then stayed at that level for 6 hours. But the application was not frozen, since Windows task manager reported it as still responding. I was able to repeat the same problem two nights running. In these cases I was running AR on a ripped library of about 2500 tracks on a network share. However when I ran AR on my main library of about 12000 tracks on local USB hard disk, then AR did not freeze...
      • AndrewFG
        • May 2010
        • 59
        BTW here is a screen shot...
        • Core1024
          • Mar 2014
          I'm having the same problem, but it's frozen at about 60%. It was stuck at least 8 hours before I killed it and started again - it got stuck at the same point with the same icons the 2nd time.
          Given that it doesn't tell you what it's doing (and the modal dialog is super-annoying too), I have no idea what it's stuck on
            • 43980
            Is the music on a network share?
            • Core1024
              • Mar 2014
              Yes it is.
                • 43980
                If you are able to, bring the files to a local hdd, this freeze seems to be the network sharing locking up.
                • Core1024
                  • Mar 2014
                  Thank you Spoon; this isn't really practical, but maybe I could do it in pieces sometime, if I can find time to do so
                  • astromo
                    • Mar 2012
                    • 18
                    My music digital library is on the local hdd but I've got other PCs and a NAS on a Windows homegroup network. I've had the same kind of hang problem. I tried leaving the homegroup so I limited the PC in question to access the internet only. It didn't appear to make any difference.
                    So, I rolled back to Release 1. I couldn't wait. I had a recent hard drive partition upser and did a mostly successful recovery. I wanted PerfectTunes to check for any dodgy files. Great piece of software that's saved me a fair bit of hassle working through the recovery process.
                    Any thoughts to add a report function? Say, export to text file.
                    Also, the software appears to need to "listen" to all tracks every time it works. Why not work with a time stamped database to review whether a track has already been listened to, so that a "next time" is a streamlined affair?
                    Thanks ..
                      • 43980
                      It does store in a database, if this is not happening, check:
                      %appdata%\PerfectTUNES
                      this is where the database is saved to
                      • dudism
                        • Mar 2014
                        upgraded to version 1.5 today and I am finding it much slower verifying albums on external usb hard drive. Version 1.0 was very fast and I'm downgrading to version 1.0 after posting this feedback.
                        I'm also noticing some weird formatting issues in version 1.5 (see below).
                        verified with version 1 = perfect!
                        Ride - Nowhere [AccurateRip DiscIDs: 011-0015F267-00BCCCA1-960C3D0B]
                        Track 1: AccurateRip Verified Confidence 18, Pressing Offset +0 [ARv2 CRC 5C9B2532] C:\check audio\01 Seagull.flac
                        Track 2: AccurateRip Verified Confidence 20, Pressing Offset +0 [ARv2 CRC 728B227E] C:\check audio\02 Kaleidoscope.flac
                        Track 3: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC 2C33EAD9] C:\check audio\03 In A Different Place.flac
                        Track 4: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC A419D36B] C:\check audio\04 Polar Bear.flac
                        Track 5: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC 5380AA84] C:\check audio\05 Dreams Burn Down.flac
                        Track 6: AccurateRip Verified Confidence 18, Pressing Offset +0 [ARv2 CRC 134132A3] C:\check audio\06 Decay.flac
                        Track 7: AccurateRip Verified Confidence 18, Pressing Offset +0 [ARv2 CRC 5C4DC17C] C:\check audio\07 Paralysed.flac
                        Track 8: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC 4D683A84] C:\check audio\08 Vapour Trail.flac
                        Track 9: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC C4267185] C:\check audio\09 Taste.flac
                        Track 10: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC 0882ABC1] C:\check audio\10 Here And Now.flac
                        Track 11: AccurateRip Verified Confidence 19, Pressing Offset +0 [ARv2 CRC FCA72F5F] C:\check audio\11 Nowhere.flac
                        some albums are having bizarre formatting issues when verified with version 1.5 (note the CRC being correct against " Track 1" on the CD, but the CRC for 02 Kaleidoscope.flac on the first line should be "728B227E", not "5C9B2532" so the way it's formatted below makes it incorrect.
                        Track 1: AccurateRip Verified Confidence 18, Pressing Offset +0 [ARv2 CRC 5C9B2532] C:\check audio\02 Kaleidoscope.flac
                        Track 2: AccurateRip Verified Confidence 20, Pressing Offset +0 [ARv2 CRC 728B227E] C:\check audio\01 Seagull.flac
                        This next CD is too rare for accurateRip (verified via version 1.5), but I believe it would have had the same CRC problem had it been in accurateRip. E.g. track1's CRC against 02. Feel So Good.flac
                        Jefferson Airplane - Bark [AccurateRip DiscIDs: 011-0012612b-009ef881-920a730b]
                        Track Not Present in AccurateRip C:\check audio\02. Feel So Good.flac
                        Track Not Present in AccurateRip C:\check audio\01. When the Earth Moves Again.flac
                        Track Not Present in AccurateRip C:\check audio\03. Crazy Miranda.flac
                        Track Not Present in AccurateRip C:\check audio\04. Pretty as You Feel.flac
                        Track Not Present in AccurateRip C:\check audio\05. Wild Turkey.flac
                        Track Not Present in AccurateRip C:\check audio\06. Lawman.flac
                        Track Not Present in AccurateRip C:\check audio\07. Rock and Roll Island.flac
                        Track Not Present in AccurateRip C:\check audio\08. Third Week in the Chelsea.flac
                        Track Not Present in AccurateRip C:\check audio\09. Never Argue with a German If You're Tired or European Song.flac
                        Track Not Present in AccurateRip C:\check audio\10. Thunk.flac
                        Track Not Present in AccurateRip C:\check audio\11. War Movie.flac
                        Please note that the metadata in these 2 albums is perfect, so I'm not sure why it's putting track 02 on the first line. I'm going back to version 1 until the bugs are ironed out.
                        • dudism
                          • Mar 2014
                          Here's one more verify if it helps you
                          Version 1 = perfect
                          U2 - 1981a - October [AccurateRip DiscIDs: 011-0011D14B-0098E01D-A109A30B 011-0011D2CB-0098E9DC-A309A30B]
                          Track 1: AccurateRip Verified Confidence 24 [CRC BEA7D4F8] C:\checkaudio2\U2 - 1981 - October - 01.m4a
                          Track 2: AccurateRip Verified Confidence 25 [CRC 942C0D04] C:\checkaudio2\U2 - 1981 - October - 02.m4a
                          Track 3: AccurateRip Verified Confidence 25 [CRC B8A667BA] C:\checkaudio2\U2 - 1981 - October - 03.m4a
                          Track 4: AccurateRip Verified Confidence 25 [CRC 739A7C8F] C:\checkaudio2\U2 - 1981 - October - 04.m4a
                          Track 5: AccurateRip Verified Confidence 25 [CRC 4FE05AE0] C:\checkaudio2\U2 - 1981 - October - 05.m4a
                          Track 6: AccurateRip Verified Confidence 23 [CRC F00F043E] C:\checkaudio2\U2 - 1981 - October - 06.m4a
                          Track 7: AccurateRip Verified Confidence 23 [CRC 42C8A521] C:\checkaudio2\U2 - 1981 - October - 07.m4a
                          Track 8: AccurateRip Verified Confidence 25 [CRC DAA16A90] C:\checkaudio2\U2 - 1981 - October - 08.m4a
                          Track 9: AccurateRip Verified Confidence 24 [CRC 1F8E544A] C:\checkaudio2\U2 - 1981 - October - 09.m4a
                          Track 10: AccurateRip Verified Confidence 25 [CRC 9A5FAEF6] C:\checkaudio2\U2 - 1981 - October - 10.m4a
                          Track 11: AccurateRip Verified Confidence 25 [CRC BACAAB5C] C:\checkaudio2\U2 - 1981 - October - 11.m4a
                          version 1.5 - the crc's stay in the same places, but against the wrong track. e.g. the real AccurateRip CRC for "U2 - 1981 - October - 04.m4a" should be "739A7C8F"
                          U2 - 1981a - October [AccurateRip DiscIDs: 011-0011d2cb-0098e9dc-a309a30b]
                          Track 1: AccurateRip Verified Confidence 24 [CRC BEA7D4F8] C:\checkaudio2\U2 - 1981 - October - 02.m4a
                          Track 2: AccurateRip Verified Confidence 25 [CRC 942C0D04] C:\checkaudio2\U2 - 1981 - October - 01.m4a
                          Track 3: AccurateRip Verified Confidence 25 [CRC B8A667BA] C:\checkaudio2\U2 - 1981 - October - 04.m4a
                          Track 4: AccurateRip Verified Confidence 25 [CRC 739A7C8F] C:\checkaudio2\U2 - 1981 - October - 03.m4a
                            • 43980
                            Can you upload this 'C:\check audio\01 Seagull.flac' whole album to dropbox for us?
                            • dudism
                              • Mar 2014
                              http://www.dbpoweramp.com/email.htm
                              I put the 2 albums above in dropbox folder and shared the folder with your email. Hope this helps you fix software :D
