MP3 Click Remover
  • No_OnE
    • Jul 2005
    MP3 Click Remover
    Hey, new to the forum, very long-time dMC user:
    Most people have noticed the 20 millisecond blank space (the "click") that the mp3 format creates at the start of each file. It is a bit of a pain because like on live CD's that you get from a friend in mp3 format, you can't burn or listen to without a click between tracks. I was just wondering if you guys could make a PowerPack plugin to remove this gap when you are converting from mp3 to a different format (I.E. Mp3 to wav to get rid of the click so you can burn to CD and play gaplessly). Thanks a ton!
    • 46218
    Re: MP3 Click Remover
    dMC R12 should auto remove this gap, a number of months away.
