Tracker Formats
  • HerrOber
    • Jun 2005
    Tracker Formats
    Maybe it's a little far fetched, but I would appreciate few tracker formats.
    Can be difficult, but maybe you guys can share some thoughts on this?
    Formats are:
    Musicline Editor (Amiga)
    Maniacs Of Noise (Amiga? c64?)
    Jeroen Tel (Amiga? C64?)
    Ben Daglish (Amiga? C64?)
    Would be kindly appreciated.
    Regards
    • 46218
    Re: Tracker Formats
    Try the winamp input adaptor (and find a winamp plug in).
    • HerrOber
      • Jun 2005
      Re: Tracker Formats
      Here is the problem.
      There are no replayers for those module formats as far as I know.
      Just recently found a module replayer which supported Maniacs Of Noise format, but there are none for Musicline Editor for example.
      • Wayne
        • Aug 2002
        • 1254
        Re: Tracker Formats
        You might have to use something other than dMC to convert them. Your could try Deliplayer or Modtracker (I think).
        Wayne
        • HerrOber
          • Jun 2005
          Re: Tracker Formats
          Great tip. Thanks very much.
          Aside from that, would it be feasible to add support for .iff (Amiga sound format)?
