What about audio flash file (.swf)?
  • YMalo
    I would like to know if it's possible to add a codec for this kind of file? It would convert mp3 file to audio flash file or wav file to audio flash file.
  • Michael
    Re: What about audio flash file (.swf)?
    a lot of times the flash player imports an .mp3 that is stored in your temporary internet files folder. So maybe the mp3 you need is already on your computer!.
    An example is found at http://yhouse.no-ip.com.
    • YMalo
      The web link that you have suggested doesn't work.
      I want to know if there is a codec for dbpowerAMP to converted MP3 to swf files? Is it in your wishes to do it?
